Lockers - JeepForum.com
post #1 of 36 Old 04-21-2013, 11:46 AM Thread Starter
smartin1
Lockers
I want to put lockers on my yj but I know nothing about installing them I only know the purpose, can someone lead me in the right direction if this is something I can do myself, what to buy, what tools I'm going to need how much money I'm going to be into this for And keep in my I have zero experience with differential gearing. I have a dana30 in front and dana35 in rear
smartin1 is offline
post #2 of 36 Old 04-21-2013, 11:52 AM
Wrangler11
Wrangler11's Avatar
Try searching. If you've never installed a locker or referred you probably don't want to try and do it yourself.
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #3 of 36 Old 04-21-2013, 12:57 PM
roadyrob
1987 YJ Wrangler
a lunchbox locker is doable even for a rookie, checkout aussie or spartan. there are some videos on youtube that will show you whats involved.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #4 of 36 Old 04-21-2013, 02:24 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You don't want to lock the rear. Well, the rear you have currently. The Lunchbox locker idea is great for the front but without knowing anything about your jeep let alone your wheeling habits or locations we can't help. Throw out a little more info and fill in your profile and then let's try this again.
Luck Favours The Prepared
Anticanman is offline
post #5 of 36 Old 04-21-2013, 02:35 PM Thread Starter
smartin1
Why don't I want to lock the rear?
smartin1 is offline
post #6 of 36 Old 04-21-2013, 02:38 PM
grnd93
D35 is a notoriously weak axle and locking it only adds stress. But many other factors come into play such as tire size and driving style.
That being said, I have a locked 35 in my TJ and I love it. I know it will break some day, that just gives me an excuse to upgrade.
grnd93 is offline
post #7 of 36 Old 04-21-2013, 02:39 PM
Jr76
Junior Member
1976 CJ7
They brake ****.
They are tuff on tires in town, prone to bad handling when off and on the go go pedal.
Sounds like gremlins are tearing poop apart when you go around corners.
If you play in the ice and snow they tend to slide down the crown of the road.
But I say go for it, for the $ a lunchbox can be a lot of fun.
Jr76 is offline
post #8 of 36 Old 04-21-2013, 02:40 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yep. Them goes boom.
post #9 of 36 Old 04-21-2013, 04:03 PM
pasinbuy
All good advise. Just lock the front with a Aussie Locker. It is pretty easy with normal tools. The direction will say that you do not need to replace the front seals. Do replace both seals! When installing the locker watch the shims that come out closely and re-install two of the shims. Go slow and be organized. Now for the best advise when you ask a question on the forum.
Please fill in your profile completely. It helps us to help you without asking you questions that should be in the profile.
pasinbuy is offline
post #10 of 36 Old 04-21-2013, 05:22 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Excellent advice guys.
If the OP wants help, he'd do what you advised first. Otherwise, sage advice isn't something that's going to happen, at least by me.
Joe Dillard is offline
post #11 of 36 Old 04-21-2013, 08:04 PM
linusb
Front Aussie or similar auto locker fairly easy. I'd never been in my differential before and I've got mine in with 7 or 8 thousand miles under her and no issues. I chickened out on doing the seals.
Hardest part I think was getting carrier out as well as back in. The latter wasn't hard. But it just didn't feel like it was going in right. The locker is one of my favorite mods. Most bang for the buck for improving off road performance in my opinion.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #12 of 36 Old 04-21-2013, 08:44 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Originally Posted by Jr76 View Post
They brake ****.
Howdy neighbor!
My Lockright front doesn't make any noise and has great manners.
YJOTM JULY 2014
DirtKar is offline
post #13 of 36 Old 04-21-2013, 09:51 PM
kjg26
kjg26's Avatar
In the front, with the factory disconnect set up....an auto locker would be essentially invisible correct? With ZERO effect on road manners. once in four wheel drive it will be apparent...correct? If I were to stitch to a tj/XJ pass side shaft, would the locker still be invisible in 2 wheel drive? Clicking? Affect on steering?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #14 of 36 Old 04-21-2013, 10:29 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The locker is invisible until power is sent to it in 4wd.
post #15 of 36 Old 04-21-2013, 10:55 PM
kjg26
kjg26's Avatar
Any clicking? Noise?
kjg26 is offline
