Locker, or not a locker? - JeepForum.com
post #1 of 3 Old 06-10-2010, 08:17 AM Thread Starter
Mike89db
Well everybody, me and my friends got a free yj (beat to hel*) and I found what looks like it could be some kind of locker? Possibly? This is on the right side of the front axle if you were looking from the back. I believe it to be an hp d30. Its kind of like a square housing with two gears inside. Over the two gears is this circular object that can slide between the two cgears and connect them.
pics.....
http://i991.photobucket.com/albums/a...563E693B3E.jpg
This unit is cable driven that has a fork on the end which will slide the circular peice left and right.
So any ideas?
1999 cherokee limited
IRO 3" lift (full 3.5" leafs/ 1" shackles), 3/4" and 1" coil spacers (stacked), RC control arm drop brackets Bilstein 5100's, AA SYE, Tom Woods driveshaft 32" KM2's.
Mike89db is offline
post #2 of 3 Old 06-10-2010, 08:23 AM
chriskeenan
its the vacuum disconnect axle thats been modified to use a cable, it locks the inter shaft to the outer shaft in 4wd mode, not a locker, but the cable actuated mod is still a good thing cause you dont have to worry about the vac lines breaking and losing your 4wd
chriskeenan is offline
post #3 of 3 Old 06-10-2010, 08:33 AM Thread Starter
Mike89db
Ok, i get it now. Thanks for letting me know. I guess this is a good thing, considering the previous owner welded the diff.
Mike89db is offline
The Grizzly Locker, The Spartan Locker, and The Zip Locker (Yukon's latest...) Apollo12227 YJ Wrangler Technical Forum 25 04-07-2013 08:35 AM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
LOCKER ISSUE > Just installed lunchbox locker - problems msavard TJ Wrangler Technical Forum 7 12-26-2006 11:11 PM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 03:14 PM
