Locker Installed - JeepForum.com
post #1 of 6 Old 03-25-2005, 10:54 PM Thread Starter
wasaw
Locker Installed
Does everyone feel stupid when they post a question? We just installed an Aussie on a '91 YJ. When in 2-wheel drive, is the front drive shaft supposed to turn all the time. Mine is and it's rubbing the exhaust pipe down tube. Will the shaft always be turning because of the locked carrier? Does anyone else have trouble with their front driveshaft rubbing against their exhaust downtube? The front axle is unlocked; we pulled the posi-lock and checked that out. Anyone with an idea?
wasaw is offline
post #2 of 6 Old 03-25-2005, 11:07 PM
kg6mti
1987 YJ Wrangler
I have read in other posts that "Yes" your front shaft will turn all the time now because of the locked carrier.
Jeep
Experience is what you get when you get what you didnít want.
kg6mti is offline
post #3 of 6 Old 03-26-2005, 12:39 AM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
It will always turn. My EZ does the same. The left front will always be "on" and turn the shaft. Only the front passenger wheel will disconnect in 2 wheel drive. It is no problem. Obviously you need to fix the rubbing thing. MIne rubbed once because it was not tight where it attaches to the manifold. Make sure the bolts are tight. You can fix it. It is a problem with the exhaust tube not the driveshaft.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #4 of 6 Old 03-26-2005, 04:31 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
It sounds like the drive shaft is too close to the pipe anyway, spinning or not. If you ever plan to go off-road, and since you put in a locker I assume that to be the case, you will want that shaft to have lots of room to move around.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #5 of 6 Old 03-26-2005, 05:28 AM
sticksnstonesru
Mine was rubbing right up until the downpipe broke at the flange. I didn't realize it was such a weak join till I pulled the downpipe off. Turns out to have been pretty rusty as well. Just a few jarring blows while wheeling was enough to snap it. The replacement downpipe I got from Advanced Auto for $65. Sits a couple inches from the front DS now. Still a low point though...
1993 YJ | 2.5L 4 banger | 3.5" Superlift | 1" BL | 4.88's | 33" BFG's |
2007 Toyota Tundra Crew-max | 4x2 | 5.7L | Truxedo Tonneau | 20"'s | Leather | Fully debadged
1999 XJ | stock | 4.0
sticksnstonesru is offline
post #6 of 6 Old 03-26-2005, 07:09 AM Thread Starter
wasaw
Thanks guys
Thanks to kg6mti, paultyler, JeeperDon, and sticksnstoneru for putting my mind at rest. I just wasn't sure if I had one problem or two. And yes, JepperDon, we're doing the work on this YJ so we can go and attack an area about a hundred miles from Nashville called Monteagle Mt. Once we get this rubbing fixed, and install the 8.8 that's sitting in the basement, we just might be ready to go. Thanks agains, guys.
wasaw is offline
Ox Locker installed N2rock JK Wrangler Technical Forum 22 10-24-2013 12:50 AM
aussie locker installed - front d30 elephantrider TJ Wrangler Technical Forum 5 08-10-2009 04:44 PM
LOCKER ISSUE > Just installed lunchbox locker - problems msavard TJ Wrangler Technical Forum 7 12-26-2006 11:11 PM
Yukon Awesome 35 OX Locker Installed TJ-Rex TJ Wrangler Technical Forum 17 10-30-2005 01:21 AM
installed locker last night...but scared...should i be?? jackal TJ Wrangler Technical Forum 4 02-04-2004 10:39 PM
