locker front or rear??? - Page 4 - JeepForum.com
post #46 of 50 Old 08-19-2011, 01:28 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by armyjeep85 View Post
thanks everyone for all the info and your ! he went with an e-locker in the front!
and for the record, my CJ is your YJ's daddy!!!!!
i kid, i kid!!!
thanks for all the help!
If he's got the money to go full carrier and E-locker to boot, good for him. Best of both worlds. Locked when you need it, open when you don't...
Luck Favours The Prepared
Anticanman is offline
post #47 of 50 Old 08-19-2011, 03:08 PM
giggityjeeper
posi kit and weld will do the same thing..... sorta... poor man selectable locker lol....
I run a posi in the front, and welded it, I run low range off road, so it is 3 wheel drive when in low range, with power to the driver wheel, when I pull the cable, and the collar slides over, now I R lockededed... and ya do the front... regardless......
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #48 of 50 Old 08-19-2011, 06:38 PM
plumber1
WOW I would have said rear over front if I was to only have 1 locker. I have ARB's F&R and I use the rear 10 to 1 over the front. Not that would lock a D35 either but take that out of the mix, I would go rear first. I have not had other such as lunchox type lockers. I only know that when I lock the front in it is VERY DIFFICULT to get the jeep to make turns, it wants to keep going straight. I do a lot of rock type trails and still very rarely need both locked up. I just did the Rubicon a few weeks ago and only locked the front twice for about 20 feet each time, I had the rear locked all day.
Again it makes it hard to make turns with front locked up on mine
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #49 of 50 Old 08-19-2011, 07:01 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Sounds like you took some challanging lines.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #50 of 50 Old 08-19-2011, 07:21 PM
oldtime_ironman
That's kinda what I was trying to say before about locking the rear. If I could only have one locker. Which is usually how it is.
oldtime_ironman is offline
front locker vs. rear locker Snydermann TJ Wrangler Technical Forum 44 11-28-2009 08:41 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 09:45 PM
Locker--front or rear? pezley69 YJ Wrangler Technical Forum 19 09-08-2006 10:27 AM
Locker? Front or Rear mikeumkc TJ Wrangler Technical Forum 17 04-28-2006 07:26 PM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 04:14 PM
