locker front or rear??? - Page 2 - JeepForum.com
post #16 of 50 Old 08-16-2011, 06:31 PM Thread Starter
armyjeep85
My neighbor has a 95 yj, 4.0 locked in rear only and running 35s. He's never had a problem with his. And he said do the rear because if you do the front, the driveshaft will always be spinning, since he doesn't have lockout hubs..
I'm not sure if he's going to run a full time locker or one he can disengage, I'll find that one out..
And yes I'm fully aware yj did not come with front lock out hubs..!
armyjeep85 is offline
post #17 of 50 Old 08-16-2011, 06:41 PM
92 Green YJ
92 Green YJ's Avatar
Originally Posted by Xpress View Post
^Except the D30 is a lot stronger than the D35, so there shouldn't REALLY be a need to carry spare shafts unless you're rocking some 37" monsters and are climbing rocks.
Lol, you need to go wheeling with me some time. I typically blow a front shaft every time I go out. I carry 2 spares per side fully assembled. Takes me under ten minutes to swap one out anytime anywhere. A locked 30 can and will blow shafts. Trust me
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #18 of 50 Old 08-16-2011, 06:46 PM
1murderedjeep
just wonder wouldnt the front be better for the fact that those are the first thing to run over rocks and such.
1murderedjeep is offline
post #19 of 50 Old 08-16-2011, 07:04 PM
92 Green YJ
Exactly. That and most of the weight is biased towards the front of the vehicle as well with the engine and such. Also weight transfer on descents. Climbs the weight shifts to the rear so it's not going to help as much in that scenario
My
post #20 of 50 Old 08-16-2011, 07:20 PM
Xpress
You're still running 35" tires though
Also depends on the type of wheeling you do, for example, trails wouldn't give you issue. If all you climb through is 25"+ tall rocks and ruts deeper than your jeep is tall, then yeah you're gunna break something.
All about that unibody life.
Xpress is offline
post #21 of 50 Old 08-16-2011, 07:23 PM
jbeebe
front
jbeebe is offline
post #22 of 50 Old 08-16-2011, 07:36 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I broke my d30 shafts climbing rocks on 33s with a 2.5l the D30 is only good for 35's max imo
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #23 of 50 Old 08-16-2011, 07:50 PM
jeepyj13
Lock fron the hp30 the yjs came stock with can handle more than the stock d35 locked can. Some i hear get lucky, lock the d35 with 33-35" tires and wont have a problem but idk i still run the 35 with 33s open and hasnt exploded yet but my yj is dd and since where i live is nothing but mostly flat land and rarely rains it too it doesnt see as much offroad as it should be seeing and plus im still in school.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #24 of 50 Old 08-16-2011, 09:26 PM
92 Green YJ
True. I didn't blow my first joint until I stepped up to 35s. Supposedly the 760x joints hold up better, but TJs are hard to find in the junkyards around here. XJs are all over so it's fast and easy to grab shafts from them for spares for cheap, so I keep running the smaller joint shafts.
My
post #25 of 50 Old 08-16-2011, 11:59 PM
yjluv
Lock the front first. I did and love it!
yjluv is offline
post #26 of 50 Old 08-17-2011, 12:26 AM
lckdrgn
I flat tow my yj all the time behind my motorhome. Will locking the front cause many issues? Running 4:88's with D30 upfront and 8.8 rear.
Thanks
BDS 4 1/2, SYE, DS Woods, Ford 8.8 4:88, Duratrac 33x12.5, BESKR Bumpers. Shrockworks Sliders,
lckdrgn is offline
post #27 of 50 Old 08-17-2011, 01:40 AM
tankinyj
a locked front will pull you through/over anything
tankinyj is offline
post #28 of 50 Old 08-17-2011, 08:08 AM
nitecop
My front 30 has had a lock-rite for the last 70K miles or so, never done anything more than change the gear lube once a year.
Also in that time I have wore out 2 ujoint on each side. never enough to hut a shaft.
I run 32s.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #29 of 50 Old 08-17-2011, 08:11 AM
92 Green YJ
Thanks
It's not a bad idea to disco the front driveshaft when flat towing with a front locker. At least with a lunchbox or auto locker. With a selectable it's not a problem.
My
post #30 of 50 Old 08-17-2011, 08:24 AM
4.7stroker
The front spinning all of the time is a non issue, just balance the front ds if you need to.
I have a 8.8 lsd in the rear and a lock rite locker in the front, I can go places that scare me.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
front locker vs. rear locker Snydermann TJ Wrangler Technical Forum 44 11-28-2009 07:41 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
Locker--front or rear? pezley69 YJ Wrangler Technical Forum 19 09-08-2006 09:27 AM
Locker? Front or Rear mikeumkc TJ Wrangler Technical Forum 17 04-28-2006 06:26 PM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 03:14 PM
