Locker advice for Dana 30/Ford 8.8 - JeepForum.com
post #1 of 15 Old 09-11-2011, 10:42 PM Thread Starter
jvallery
Hi Folks,
I'm in the middle of a build and I am trying to consider the various choices for lockers. My Jeep will be mostly a daily driver/trail rig. I'm not looking to do crazy rock crawling and when a decision needs to be made that favors on/off road performance I want to err on the side of on-road.
That being said, I'm trying to determine about what I should do from a locker perspective. In the front I've got the stock Dana 30 with 3.73 gears. In the rear I've got a Ford 8.8 with the limited slip diff that came with it (3L73 are the markings).
My gut says to leave the Ford 8.8 alone and upgrade the Dana 30. It seems to work okay (although I've not actually had it on the road yet - see build thread). I don't want to spend a ton of money on an ARB/OX locker in addition to all of the drama involved in routing cables/air lines. My first thought was what about Detroit?
I can get a Detroit locker via Summit for $549 and I wouldn't need anything additional?
http://www.summitracing.com/parts/DTL-162SL60B/
Would that add enough value over top of the stock diff to justify the cost and work? Would that make my setup make my rig fairly capable on the trail? Are folks running the Ford 8.8 factory limited slip setup generally happy with the performance of it?
Just looking for general thoughts on this combo.
Thanks!
-JV
jvallery is offline
post #2 of 15 Old 09-11-2011, 10:53 PM
4.7stroker
I put a lock rite lunchbox locker in the front and installed a 8.8 lsd in the rear and find it to be a good on/off road combo. The lunch box is also half the price of a selectable.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 15 Old 09-11-2011, 10:55 PM
jeepnbrett
I would suggest locking the front first. The combo of a front locker with LSD in the rear will be very capable off road. A selectable locker will give you the best of everything for on road manners and off road traction. If you don't want to spend the money or hassle with air or other lines then go with a lunchbox in the front. I ran a Lockrite in the front with the LSD rear for about 6 months and it worked well. After wanting more traction I installed Powertrax Noslip locker in the 8.8.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #4 of 15 Old 09-11-2011, 10:58 PM
clarkjdg
clarkjdg's Avatar
Dwayne
^ Ive got the same setup and I couldn't be happier!!!
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #5 of 15 Old 09-11-2011, 10:59 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Did you swap front axles or gear sets to get 3.73's in the 2.5L AX-5?
Joe Dillard is offline
post #6 of 15 Old 09-12-2011, 04:42 AM
Louie4
I have a Lock-Right in my D30 and Aussie in the 8.8. My rig is driven to the trails but not daily. I love the combination but for your build you might want to look at a Detroit for the rear and a lunchbox up front. Just a thought though.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #7 of 15 Old 09-12-2011, 05:12 AM
hesserdude07
Lock rite in the D30, Welded in the 8.8. AMAZING!!
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #8 of 15 Old 09-12-2011, 05:19 AM
RustedWrangler
My aussie in the 8.8 is almost unnoticable on the road, I just keep in mind, no accelerating around corners.
Spartan up front or any other lunchbox, if you still have the disconnect it wont do anything until you are in 4wd.
www.RCPFA.com
RustedWrangler is offline
post #9 of 15 Old 09-12-2011, 05:23 AM
CJ51973
CJ51973's Avatar
Not a big fan of a locked front, LSD in back. I had this in a CJ once. I was heading up a rock. Once the front popped up over the top of the rock the rear gave it up/went to one wheel drive and I went backwards. Kind of did a ballet move (piroet?) and ended up my spare tire was the only thing that kept me off my lid. Went home and locked the rear. May not be everyone's experience but it was mine.
I have a Detroit in the back and a Truetrac in the front. Not a DD but I do drive it 70 miles one way to where I wheel & 50 miles one way to work about a day a week in the summer. I don't notice it.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #10 of 15 Old 09-12-2011, 07:48 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
What tire size?
If you truly plan on a 6.0 SM465 Do NOT put a red cent into your dana 30. The weight and power will destroy that dana 30 every time out. The guy I wheel with the most, runs a v8 and dana 30 front. It breaks every time out...sometimes twice a trip. He will go wheeling 6-8 times a year and break 10-15 front shafts/u-joints a year.
We wheel the same obstacles, the same way. I left mine open intentionally, he locked his. I ran 35's he only ran 33's. He also ran limited slip in his rear Dana 44 so this is apples to apples of what you want to do.
In my experience if you run a V8 and lock the Dana30 you will hate life.
Lock the ford 8.8. When you are ready for a locked front end, throw the dana 30 in the trash.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #11 of 15 Old 09-12-2011, 10:10 AM Thread Starter
jvallery
I haven't installed them yet but I do have the 3.73 gears. I'll install them the same time I install whatever locker I buy.
What tire size?
I'm still trying to decide on tire size. I was planning 35s but have had feedback from a few folks that indicate you can't pass inspection in Colorado with larger than 33s. I'm not sure if that is true or not. So either 33s or 35s. I am going to be running a Chevy 5.3 with SM465 transmission. They are both already purchased and the transmission is in the shop right now getting re-built and all of the Novak stuff installed.
jvallery is offline
post #12 of 15 Old 09-12-2011, 10:25 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I would stick with the 4.10 set up especially if you ever plan for 35's. As for the 8.8, 4.10 too. As far as lockers go, poke is right about the front being significantly weaker that the 8.8 so put a selectable in the rear so you have open driving with spool offroad and for the front go with something that's gonna give a little like an ected. It's LS and has a lot of give instead of breaking axles, you just lose traction and have the option to lock it up and push a little harder. I would also definitely recommend chromos up front. It's quite an investment but totally worth it.
Luck Favours The Prepared
Anticanman is offline
post #13 of 15 Old 09-12-2011, 10:37 AM Thread Starter
jvallery
The trouble with the 4.10 gear is that if I'm cruising down the interstate at 75mph in 4th gear (SM465 has no overdrive) I'll be running at 3130 rpms with 33 inch tires. By switching that to the 3.73 I'll bring that down to 2848 which is still higher than I'd like but tolerable. Again, on-road versus off-road.
jvallery is offline
post #14 of 15 Old 09-12-2011, 11:27 AM
The_Blacksmith
1993 XJ Cherokee
aussie in the front. Weld the rear or get a full case spool.
Thanks Chris!
The_Blacksmith is offline
post #15 of 15 Old 09-12-2011, 11:47 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
5.3 and SM465.... that gives me jeep envy. good combo!
Poke is offline
Need advice(Aussie locker in ford 8.8) Quail YJ Wrangler Technical Forum 24 03-25-2012 09:07 AM
Ford Dana 44 and Ford Dana 60 Comparison highrolrcustoms YJ Wrangler Technical Forum 0 08-06-2011 07:06 PM
ARB locker in a ford 8.8 Ezalycasaid TJ Wrangler Technical Forum 3 02-28-2011 07:56 PM
79 ford f250 dana 60 direct replacment for dana 35? CDW_327 YJ Wrangler Technical Forum 9 12-13-2010 08:22 AM
dana 44/60 OR dana 44/ford 9" (pics) Michael_94YJ YJ Wrangler Technical Forum 33 06-29-2007 06:44 AM
