locker - JeepForum.com
post #1 of 2 Old 10-27-2001, 01:05 PM Thread Starter
blackjeep
locker
I have a question on what kind of locker to get for my front axle, dana 30. I have three in mind. A LOCKRITE, TRUE TRAC, or a POWER TRAX NO SLIP. im guessing any of these would hold up, but which one would be the best?
95 wrangler 1.5" springover Dana44 front Ford8.8 rear 4.10's 35x12.50 MTR's
blackjeep is offline
post #2 of 2 Old 10-27-2001, 03:12 PM
jeffy
jeffy's Avatar
Well, the TrueTrac isn't a locker. It's a Limited Slip Differential. Althought it's a tight one. It also replaces the carrier and requires more work to install. More so then the Lunchbox lockers like the Lockright and Powertrax no slip. Out of those the the No-Slip is supposed to be better. They're both made by Powertrax and they both fit into the existing carrier.
I've got a Truetrac since I got it used for cheap. Works well and since I'm turning larger tires, I don't have to worry as much about breaking the D30. Lots of people like the cost of the Lockright. For the No-slip, it's it prices close to a Detroit? Something like $500.
*** www.4BangerJP.com ***
jeffy is offline
The Grizzly Locker, The Spartan Locker, and The Zip Locker (Yukon's latest...) Apollo12227 YJ Wrangler Technical Forum 25 04-07-2013 08:35 AM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
Upgrading my Rear Locker-ARB or Rubi Front Locker? tkki1230 TJ Wrangler Technical Forum 4 05-26-2008 08:45 PM
LOCKER ISSUE > Just installed lunchbox locker - problems msavard TJ Wrangler Technical Forum 7 12-26-2006 11:11 PM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 03:14 PM
