Lock for tailgate? Need key or re-key - Page 2 - JeepForum.com
post #16 of 21 Old 05-29-2010, 12:33 PM
Burlbook48
Burlbook48's Avatar
Originally Posted by GatorsUF View Post
Ok, I got the cylinder out of the Jeep, but the pins are covered by a sheath. How do I get that off? The only way I could see was to take the black cover off the front/exposed part of the lock. I could do that but it would probably get destroyed....any tricks or what?
I have one key for both full doors, tailgate, and ignition. Bought a set of half doors, so I pulled the cylinders out of the them and had the cylinders changed to match my key. Now one key works for all 5 locks. Cost, 20 bucks at the local locksmith, and I don't have to worry about something not fitting right. I've already got too many other keys on my ring, keeping the number as low as possible was a plus for me.
Take your key in and get the tailgate cylinder made to match your ignition (and your doors if you can/want to as well).
You have to start somewhere to get to the middle of nowhere.
2015 YJ Of The Year
Thanks, but my rig is just a Prince among Kings. You folks gave me the answers to build it!
Burlbook48 is offline
post #17 of 21 Old 05-29-2010, 04:33 PM Thread Starter
GatorsUF
I should probably reword my last post, I don't have locks on my doors. I had to change my ignition when I got the jeep since it didn't require a key to start it. so now the tailgate and the ignition don't match. I only have two keys on my keychain so I am fine with another key but the locksmith wanted $70 to make one. I am fine with either a new key or I can just figure out how to get my cylinder apart so I can rekey it. I just don't care so much to pay $50 for 3 cylinders when I only have a spot for 1, but I do appreciate the responces.
Sarasota Jeep Club
GatorsUF is offline
post #18 of 21 Old 08-09-2011, 02:48 AM
kbrawlz
here is a video i made on keying all locks the same.
<iframe width="425" height="349" src="http://www.youtube.com/embed/-uv3GOfrWG4" frameborder="0" allowfullscreen></iframe>
or
http://youtu.be/-uv3GOfrWG4
i'm not good on forums, so we'll see if the video embedded itself
also, shop around. i've been to locksmiths that will make a master for $20
jeep or die
kbrawlz is offline
post #19 of 21 Old 11-11-2015, 07:36 PM
Truble
I got 2006 Wrangler. Tailgate lock won't turn. Right key, removed cylinder and all tumblers are aligned (down) but cannot turn. It's clean and bathed in WD40. But nothing. Any ideas?
Truble is offline
post #20 of 21 Old 11-11-2015, 07:39 PM
Truble
Anybody here??
Truble is offline
post #21 of 21 Old 11-12-2015, 07:21 AM
cojab
While you have the cylinder out drop it by a locksmith to see whats up with it.
cojab is offline
Tailgate Lock Question Duckhat YJ Wrangler Technical Forum 3 10-16-2006 12:44 PM
Tailgate Lock Cylinders for my 90 YJ! 90yjkrawler YJ Wrangler Technical Forum 1 07-05-2006 09:15 AM
Tailgate lock Dcomf TJ Wrangler Technical Forum 0 05-24-2006 09:22 AM
tailgate lock modification Mr. Joshua TJ Wrangler Technical Forum 4 03-14-2006 08:48 AM
Tailgate lock same as doors? Jimmylh YJ Wrangler Technical Forum 2 08-04-2003 11:09 PM
