Lock for tailgate? Need key or re-key - JeepForum.com
post #1 of 21 Old 05-21-2010, 01:59 PM Thread Starter
GatorsUF
The lock in my tailgate as far as I know is fine. The only problem is I don't have a key for it. I called the a locksmith out of 5 only one would cut me a new key from scratch (using my VIN) and it would cost $75. I don't need it that much to pay $75.
Is it easier to get the cylinder re-keyed or should I keep shopping around?
Is grinding the pins on the cylinder as easy as people make it sound? The tailgate cylinder shouldn't be too hard to get out right? Then stick in my key and shave off the pins that stick out...sound easy...is it?
Sarasota Jeep Club
GatorsUF is offline
post #2 of 21 Old 05-21-2010, 02:09 PM
muddy93
1987 FSJ Wagoneer
It's been a wile sense I did mine, but that's pretty much exactly what I did. At some point prior to my ownership, my jeep had been stolen and then recovered, and the ignition cylinder had been replaced, and my ignition key did not work for the tail gate.
Removing the cylinder is fairly simple, just remove the cover plate from the inside, and you will be able to disconnect the rod that connects the cylinder to the latch, as well as the cylinder retainer. Once the cylinder is out, it really is as simple as putting your key in, and grinding down the pins.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 21 Old 05-21-2010, 02:11 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The local locksmith charges about $25 to re-key a lock cylinder if you carry it onto his shop.
Most dealerships will cut you a new key if you provide proof of ownership for the Jeep.
CJ7-Tim is offline
post #4 of 21 Old 05-22-2010, 11:39 AM
King_
Are there any companies that sell all three together? tailgate and two door cylinders? that use one key?
King_ is offline
post #5 of 21 Old 05-22-2010, 11:53 AM
brzehentmaier
brzehentmaier's Avatar
Look on ebay. I bought a cylinder w/2keys for $14.95 a couple of years ago. I can't remember which seller it was or if he's even around anymore. He sells them for both the doors and tailgate. You'll have to do a search for them. Good luck and happy hunting.
Bernie
1995 Rio Grande
31 x 10.5 x 15 Tires
1.5 Body Lift - Skyjacker Hydros
2.5 - Auto - Crager "D" Slots
A Work In Progress
2004 Liberty Columbia Pkg.
A new begining
brzehentmaier is offline
post #6 of 21 Old 05-22-2010, 12:28 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
Maybe this would work?
Yakima 8007204 - YAKIMA SKS Lock Cores - Quadratec
-John-
johnboy68 is offline
post #7 of 21 Old 05-22-2010, 12:54 PM
Dhofstet
1973 KK Liberty
Make a bump key? YouTube - Bump Key HOWTO
Spineless, and mindless, You flex your muscles but not your F***ing head..
Dhofstet is offline
post #8 of 21 Old 05-22-2010, 01:42 PM Thread Starter
GatorsUF
Do the pins fall out if you hold it upside down. Meaning is it tedious to file the pins down without them falling out all over the place?
Sarasota Jeep Club
GatorsUF is offline
post #9 of 21 Old 05-24-2010, 08:34 AM
muddy93
1987 FSJ Wagoneer
Well, I just noticed that you have an 89, I don't know if it will be the same as my 93, or not. Dose yours use one key for the locks and ignition, or is it two seperate keys?
My 93 used just one, double sided key, and with that type of key, the lock uses little flat washer looking tumblers. That style will not fall out, as long as the key is left in the cylinder, but I don't know about the older style.
muddy93 is offline
post #10 of 21 Old 05-28-2010, 08:34 PM Thread Starter
GatorsUF
Ok, I got the cylinder out of the Jeep, but the pins are covered by a sheath. How do I get that off? The only way I could see was to take the black cover off the front/exposed part of the lock. I could do that but it would probably get destroyed....any tricks or what?
Sarasota Jeep Club
GatorsUF is offline
post #11 of 21 Old 05-28-2010, 08:43 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
my locksmith stuck a tube in the lock and looked in it.. went back inside the shop, made the key and came out to the jeep.. stuck the key in... and it worked.. $25
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #12 of 21 Old 05-28-2010, 09:28 PM
Lonan
My tailgate was different than my doors and I didn't have a key for any of them so I just got this kit. Two door cylinders and one tailgate cylinder with 2 keys. All keyed the same. Easy as can be to install. Works perfect.
Door Cylinder Kit (3 Cylinders w/Keys)*8122874K3 by the Jeep Specialists | Morris 4x4 Center
Lonan is offline
post #13 of 21 Old 05-28-2010, 09:39 PM
Burnerman
Burnerman's Avatar
^^^^ That's what I would do!
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #14 of 21 Old 05-29-2010, 11:31 AM Thread Starter
GatorsUF
If I could buy 1 lock cylinder maybe, but my doors don't have keys...I have half doors so the only lock is on my tailgate.
Sarasota Jeep Club
GatorsUF is offline
post #15 of 21 Old 05-29-2010, 11:49 AM
monkeyhouse
wait you have locks on your doors??? LOL. I don't.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
Tailgate Lock Question Duckhat YJ Wrangler Technical Forum 3 10-16-2006 12:44 PM
Tailgate Lock Cylinders for my 90 YJ! 90yjkrawler YJ Wrangler Technical Forum 1 07-05-2006 09:15 AM
Tailgate lock Dcomf TJ Wrangler Technical Forum 0 05-24-2006 09:22 AM
tailgate lock modification Mr. Joshua TJ Wrangler Technical Forum 4 03-14-2006 08:48 AM
Tailgate lock same as doors? Jimmylh YJ Wrangler Technical Forum 2 08-04-2003 11:09 PM
