Lock Right Quick Question - JeepForum.com
post #1 of 5 Old 02-07-2011, 08:46 PM Thread Starter
JakeMurray24
So I have a lock right in the box at home, and I am thinking about putting it in to play around for the week i come home from school, what I am wondering is, can I install the locker without removing the carrier? as in grinding a bit of something? I also have a spare dana 30 in the garage!
1989 YJ Candy apple Green, D30front, 8.8rear, 4:10's, Lock right front, 4"RC springs rear, 3.5"BDS springs front, SYE with double cardian shaft custom made, home made rockers, 33" goodyear mtr/k, smittybilt stinger, home made light bar, marine stereo, cobreau baja jp seats
JakeMurray24 is offline
post #2 of 5 Old 02-08-2011, 12:03 AM Thread Starter
JakeMurray24
anyone have any idea?
post #3 of 5 Old 02-08-2011, 12:06 AM
2006_Sport
You have the remove the carrier and ring gear to install the locker in your 30. If you had 3.07s you wouldn't have to because the ring gear clears the cross pin so all you would have to do is pull the carrier. Just remember to use red loctite on the ring gear bolts when you go to reinstall and torque to spec. Same with bearing caps.
FWIW I've installed 2 of these, 1 in a YJ and one in my TJ.
2006_Sport is offline
post #4 of 5 Old 02-08-2011, 05:09 AM
Louie4
Like said above the 3.07's won't allow you to remove the cross pin unless you remove the carrier and ring gear. I recommend marking the carrier bearing caps and keep the races to their appropriate side so you can install it the same way you took it out. I also marked my ring gear in relation to the carrier just for peace of mind.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 5 Old 02-08-2011, 06:15 AM
MLJeeper
MLJeeper's Avatar
Pulling the carrier really is no big deal. Dont let it scare you, as others mentioned just mark everything and put it all back in just like you found it. Game on.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
quick question on a home made posi-lock broken-wrangler YJ Wrangler Technical Forum 4 12-12-2009 10:14 PM
Quick question about rub at full lock BtownFord YJ Wrangler Technical Forum 9 02-04-2009 09:01 PM
quick door lock question The Hippie YJ Wrangler Technical Forum 10 11-01-2007 02:15 PM
quick lock right question RnEmOvr TJ Wrangler Technical Forum 4 03-20-2007 08:37 AM
Quick Question about Tailgate Lock massyj YJ Wrangler Technical Forum 3 04-12-2006 01:52 PM
