lock right made selectable - JeepForum.com
post #1 of 3 Old 02-24-2010, 10:38 AM Thread Starter
mojeep
A posi lock can do the same thing but my vaccum disco works fine so i bought a 1/4" 3-ball valve from grainger removed the hard line from the check valve on the firewall ran a new line into the cab to the bottom of valve then ran two new lines from valve outputs inside cab to frontend with plenty of slack for flex hooked one on each side of disco and with the turn of a lever i can lock and unlock the pass side, this is only usefull with a locker of course, and my 4x4 light works in conjuction. works pretty sweet,anyone done this? I know pics would be nice but dont have a cam, very easy to do maybe 15min.
mojeep is offline
post #2 of 3 Old 02-24-2010, 10:44 AM
RockWoRM
RockWoRM's Avatar
Sounds interesting... but yes, pics would be nice.
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #3 of 3 Old 02-24-2010, 11:52 AM
muddy93
1987 FSJ Wagoneer
I did this, however, all of my vac lines were in decent shape, so I just unhooked them from the T-case and re-routed them into the cab and up to the dash. Also, I used a rotary type valve, 1/4 turn of the knob locks/unlocks the disconnect. I left the vent port on the valve open behind the dash, so I get a cool "shshsh" sound when I turn the knob.
One thing I have noticed though, you need to either be sitting still, or have the T-case already in 4wd, before you engage the axle disconnect. If not, you'll get a "bang" when the axle engages and starts to turn the drive shaft.
even if you don't have a front locker, this mod gives you the ability to have 2LO, which I find that I use quite a bit for moving the trailer around the property.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
4x4 POSI-LOCK!(HOME-MADE??) BIG SEXY YJ Wrangler Technical Forum 10 02-26-2011 10:45 PM
leave the 8.8 open until i get a selectable locker or go ahead with an aussie or lock jeepin01tj TJ Wrangler Technical Forum 11 10-28-2009 05:30 PM
Homemade Posi Lock + Aussie Locker front = Selectable locker??? Toms87 YJ Wrangler Technical Forum 20 03-11-2009 09:03 PM
home made Posi-Lock Killrdanasurfer YJ Wrangler Technical Forum 10 04-03-2006 01:44 PM
Home-made Posi-Lock peltdrummer YJ Wrangler Technical Forum 4 12-25-2003 01:27 PM
