lock right issue - JeepForum.com
post #1 of 7 Old 03-02-2013, 04:30 PM Thread Starter
myers1122
lock right issue
Have a 1995 jeep YJ with a dana 30 up front had a lock right locker installed a while back busted an outer axle shaft so i upgraded to the chrome molly axles ( the one on the right hand side done away with the shift fork that locks the two axles together ) (ONE PIECE AXLE ) now it seems like both are locked at all times cant turn it on the pavement. any ideas or remedies >?
myers1122 is offline
post #2 of 7 Old 03-02-2013, 05:33 PM
BlueRubiconrich
yeah that was the way they used to unlock the front axle now you added a one piece shaft. try lock out hub conversion or change out to CJ style bolt pattern with lock out hubs
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 7 Old 03-02-2013, 08:05 PM
TSEJEEPERS
Check your transfercase linkage. It sounds like it is not shifting out of 4 wd.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 7 Old 03-02-2013, 08:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Did you check the locker after the shaft install? It seems that it may have moved around a little inside and it wasn't unlocking at all. The one piece shaft will make the steering a little taut but not that you can't turn. The locker works with power added through the driveshaft so there is a problem with the linkage and there's power or the springs aren't spacing it out at all.
Luck Favours The Prepared
Anticanman is offline
post #5 of 7 Old 03-02-2013, 09:27 PM
wayno32m
wayno32m's Avatar
Sounds like the same thing that happend to me when I went to the one piece axel shaft, figured out that the lock rite was not set up to correctly the first time (the gap tolerence on the locker was slightly off) I ended up adding an extra thrust washer (maybe a worn carrier), looked good to the eye but when I measured with a digital caliper it was to wide of a gap/tolerence. At least that was my expierience. Good luck
wayno32m is offline
post #6 of 7 Old 03-04-2013, 10:02 AM
bogleparsons
This is most likely your problem.
Open the diff again and check the locker with feeler gauges to ensure correct tolerances.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #7 of 7 Old 03-05-2013, 07:34 PM Thread Starter
myers1122
Good deal.
I hope this is it
Thanks
