Lock right install/ D30 question - JeepForum.com
post #1 of 3 Old 02-18-2014, 11:36 PM Thread Starter
Gausswave
I have the 4.10 gear set which means you have to remove the carrier. When you reinstall the carrier there was a C clip on the passenger side axle.
It's not mentioned but I take it you don't reinstall the clip with the lock right?
Over all it's a pretty basic install but I can't get around this detail and I guessing since there isn't any room you can't make it happen anyway.
Gausswave is offline
post #2 of 3 Old 02-18-2014, 11:46 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You don't need the c clip. The shafts are held in place if there is a wheel and unit bearing attached. If not, you're gonna need more than a c clip
Luck Favours The Prepared
Anticanman is offline
post #3 of 3 Old 02-19-2014, 12:09 AM Thread Starter
Gausswave
Thanks! That's what I figured but I get hung up on details. Like if that was the case then why did they have one in the first place? I don't see the need. Incase some one needed to run with out the outer axle?
