Lock cylinders - JeepForum.com
post #1 of 6 Old 02-05-2013, 11:27 AM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Lock cylinders
Does anyone know if the lock cylinders for the ignition are interchangeable between the YJ years. I have an 87 with the GM style lock cylinder and I want to do the newer style double sided key. I am replacing my tailgate lock cylinder because I dont have a key to it. The new replacement comes with a newer style key. Long story short I would like to use the same key for both and if I can use a newer style key in the ignition I can change the pins to match the tailgate lock cylinder. Thanks.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #2 of 6 Old 02-05-2013, 12:26 PM
Rproject
1987 YJ Wrangler
I believe the will not interchange, but I may be wrong. It's been a while since I've those columns apart.
Why not just replace the tailgate lock cylinder with the same style as is currently in place? Or take the lock cylinder to a locksmith and have them fit a key to the existing lock?
You say you can change the pins to match the tailgate cylinder. You have the rekeying kit? They're generally not available to the general public.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 6 Old 02-05-2013, 12:34 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Well, for one I hate my GM key, dont ask.. its just preference. Tumblers are availible to purchase on the internet or you can purchase parts from your local lock smith.
I watched this video and it seems super easy to do.
http://www.youtube.com/watch?v=-uv3GOfrWG4&feature=youtu.be
March 2017 YJOTM
87TPIYJ is offline
post #4 of 6 Old 02-06-2013, 09:18 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Bump. Anyone know for sure? I have read other places yes, but know one had said they had actually done it .
March 2017 YJOTM
87TPIYJ is offline
post #5 of 6 Old 02-13-2013, 12:03 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
March 2017 YJOTM
87TPIYJ is offline
post #6 of 6 Old 02-13-2013, 12:49 PM
Que89YJ
Why not call a locksmith to make sure. The lockcylinder is definitely diffeent but that doesnt mean it will not work in the older column. They will definitely know for sure. Post back.
Que89YJ is offline
