Location of 'bleed valve' for hydraulic clutch - JeepForum.com
post #1 of 5 Old 04-02-2013, 12:31 PM Thread Starter
befumo
On an 89 with the AX-15? Or is this not even possible transmission has to be dropped?
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #2 of 5 Old 04-02-2013, 12:44 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Read this: http://www.jeepforum.com/forum/f12/c.../?nojs=1#links
I found it using the Search Feature here on the YJ tech Forums.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #3 of 5 Old 04-02-2013, 01:28 PM Thread Starter
befumo
I saw that thread earlier, did not read it through because it did say it was a replacement.
So i take it assuming the engine is off when you pump the clutch and you have the cap open or any source open (even if its up by the master cylinder) its safe to say the air would travel upwards to the master and then purge through?
'89 YJ Islander
befumo is offline
post #4 of 5 Old 04-02-2013, 01:33 PM
JeepinJeremy
bleeder is located at the slave where the lines go in the bell housing
JeepinJeremy is offline
post #5 of 5 Old 04-02-2013, 01:33 PM
Old4X
1990 CJ7
Bleed the air like any other closed hydraulic system. Pressurize it, crack the bleeder, close. Repeat as necessary to get air out.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
