location and access to rollover valve - JeepForum.com
post #1 of 4 Old 02-09-2013, 06:30 PM Thread Starter
tkwok
I can't seem to find the rollover valve on my 95 YJ. I've read on here that it's somewhere in the passenger side rear wheel well. I'm having the fuel smell issue when my Jeep is running so I want to inspect the rollover valve. The fuel filter on my YJ is on the rear driver side. Is the rollover valve also on this side? Do I need to drop the fuel tank in order to gain access to it?
thanks
tkwok is offline
post #2 of 4 Old 02-09-2013, 06:38 PM
jokerchief462
Back passenger corner of the tub. There is splash guard you have to remove to get acces it is the farthest back point in the corner. Take out splash gaurs and look up it is held in a bracket has fuel lines running to it.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 4 Old 02-09-2013, 07:46 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You don't have one located away from the tank. This only exists on '87-'90 models.
Your rollover valves are located on the top of the tank, like on the '91 I worked on in this thread.
http://www.jeepforum.com/forum/f12/h...emoval-981049/
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 4 Old 02-10-2013, 08:14 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
There is no vent to the air on a '95, the tank pressure vent line goes to the evap can in the front. The evap system could have issues too somewhere along it's path the intake. The gas cap keeps fuel vapors in, so that could cause smells if bad.
The small vent line in the left rear of the tub is for the rear axle.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline
