Load Range D and E tires on a YJ? - JeepForum.com
post #1 of 15 Old 11-04-2011, 10:49 AM Thread Starter
weerwolv
Hi everyone,
What is the major issue of running these tires on a lighter weight YJ?
How would one improve ride?
I'm looking at 265/75R 16 or 285/75R 16 tires as I prefer a more narrow footprint but it appears almost all of these tires live in the Load D and E range.
Thanks in advance,
Note: I'll spend about 70-80 percent of my time on road.
-Chris
weerwolv is offline
post #2 of 15 Old 11-04-2011, 11:14 AM
jeffmarion
The only thing will be a rougher ride due to the stiffer sidewalls on the tires. But your in a Jeep so you won't notice it too much.
jeffmarion is offline
post #3 of 15 Old 11-04-2011, 11:49 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Those load range tires are typically designed to run at high pressures (60psi+). High psi = very rough/bouncy ride in a "lightweight" YJ.
Joe Dillard is offline
post #4 of 15 Old 11-04-2011, 01:01 PM Thread Starter
weerwolv
Thanks for the feedback gents. If you do run them what pressure would you go with and would that effect anything major on the road?
weerwolv is offline
post #5 of 15 Old 11-04-2011, 05:29 PM
dodger889
There is a formula for figuring this out. Take the tire rating in pounds (max 2500 at 45psi) . that would give you a 10,000 load cap on the tires. You your yj would be about half of that. Then take the the tire max rating and your jeep weight figure out your percentage of the tire rating. Then take the max psi and use that figure plus 10-15 percent ( this is a safety feature) to give you what should be used for your air pressure.
Disclosure: these are NOT rating on all tires Please use the ratings on you tire to do the figuring on..... And under no reason run under 20 psi on the road at road speeds.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 15 Old 11-04-2011, 06:36 PM
SunDevilJeeper
So... what you mean to say is... go 95mph on the freeway at 11 psi?
EDIT: I was also trying to figure out what psi I should run at, my dunlop mud rovers have a pretty soft sidewall for the rating they have.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #7 of 15 Old 11-04-2011, 06:44 PM
superj
I had those heavier tires on something just recently, not my wrangler but something else. They are fine and last forever with the lighter vehicle
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #8 of 15 Old 11-04-2011, 08:14 PM
jeepcrazy93
Well the TJ rubicons run an E rated tire from the factory and thats what I run on my TJ. I thought it would be much worse than it actually is.
93 YJ 4.0 AX-15 33's 8.8 with CJ front clip
03 F-250 Extended Cab Long Bed with 7.3
jeepcrazy93 is offline
post #9 of 15 Old 11-04-2011, 10:11 PM
dodger889
I hope you are just trying to be funny there!
post #10 of 15 Old 11-04-2011, 10:14 PM
SunDevilJeeper
I should go post that on pirate.
post #11 of 15 Old 11-04-2011, 10:38 PM
dodger889
Hey just cover thy own butt here before someone trys to rip it......
post #12 of 15 Old 11-04-2011, 10:57 PM
SunDevilJeeper
Oh it's only a matter of time before someone comes along and thinks I'm serious.
I'll bet you a cheeseburger and fries that in a couple years, some noob is gonna bump this thread and say "really? are you serious?"
post #13 of 15 Old 11-04-2011, 11:51 PM
AmmitOsiris
AmmitOsiris's Avatar
Really? Are you serious?
AmmitOsiris is offline
post #14 of 15 Old 11-05-2011, 02:36 AM
SunDevilJeeper
See? I told you so!
post #15 of 15 Old 11-05-2011, 09:28 AM
RockWoRM
RockWoRM's Avatar
For an example; I run my 35x12.50 MTRs @ 26psi on the road. This is about where I get the best road footprint.
You can do a chalk test, where you rub chaulk on the tread and go for a test ride at a certain psi and see how the tire wears. Repeat and adjust to get best footprint and leave it there.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
Load Range D too stiff for my 03 TJ? isaacson TJ Wrangler Technical Forum 3 05-03-2011 02:55 PM
what load range is better? Jodyblip JK Wrangler Technical Forum 19 06-23-2010 04:06 AM
load range ?? 09WRANGLER JK Wrangler Technical Forum 4 04-21-2010 06:10 PM
20" Wheels & Load Range "E" Tires soundone JK Wrangler Technical Forum 0 04-27-2008 09:54 AM
