A little vibration - Page 2 - JeepForum.com
post #16 of 19 Old 01-21-2010, 09:22 PM
4.7stroker
Originally Posted by gearhead1985 View Post
get the autozone gold for the life time warranty they are decent just make sure to keep them greased
with your vibrations since you used atf not an oil you might of ate up a bearing my input bearing went out and cased the same symptoms
If ATF is not an oil then what is it? There are bearings n stuff in an auto box that must be lubricated and ATF does this just fine in them. Many manual boxes use ATF just fine.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #17 of 19 Old 01-21-2010, 09:26 PM
YJBlues
YJBlues's Avatar
The ujoint doesn't have to even be classically "bad" to cause a vibration, if it hasn't been greased in way too long it can get so it doesn't move like it's supposed to. Replace the ujoints, it's cheap insurance.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #18 of 19 Old 01-21-2010, 10:22 PM
MJMPC
Dwayne
Auto trans are made to use ATF jeep trans are not .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #19 of 19 Old 01-21-2010, 10:36 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Mike, in defense of Dwayne's position, many manual transmissions use ATF in them and is the factory recommended fluid. There's nothing wrong with using it in an AX-5 or AX-15.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
Bad Vibration. Please Help? metal_kid17 YJ Wrangler Technical Forum 8 10-26-2009 02:52 PM
Bad Vibration. Manard TJ Wrangler Technical Forum 3 02-25-2008 05:26 PM
Odd vibration JeepPirate TJ Wrangler Technical Forum 4 01-14-2008 12:03 PM
vibration igolf JK Wrangler Technical Forum 20 12-17-2007 07:26 AM
Vibration henri TJ Wrangler Technical Forum 13 04-13-2005 07:25 AM
