A little vibration - JeepForum.com
post #1 of 19 Old 01-21-2010, 03:03 PM Thread Starter
H_Swank
A little vibration
Just got through building my rig. Its got the TJ 4.0L and the AX-15 married to the NP231.
I am getting some vibration, mainly while I am decelerating without pushing the clutch. When I hit the clutch its all quite. I am running Mercron IV ATF in the tranny and xfer case.
Any suggestions would be greatly appreciated.
H_Swank is offline
post #2 of 19 Old 01-21-2010, 03:50 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
What did the AX-15 come out of?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 19 Old 01-21-2010, 04:04 PM
ritjobbie
ATF in a manual gearbox?
I'd check u-joints. Replace them all if it's never been done.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #4 of 19 Old 01-21-2010, 04:20 PM
postaldave
rear diff might be going out.
postaldave is offline
post #5 of 19 Old 01-21-2010, 05:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Very common. Many manufacturers (Volvo for one) call out ATF for their manual gearboxes.
Good idea!
Max
Mean Max is offline
post #6 of 19 Old 01-21-2010, 06:39 PM
mrmud4x4
Make sure your tranny mount bolts are tight.(on the skid plate) When you decel...tranny may be lifting a little, or rotating.
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #7 of 19 Old 01-21-2010, 06:40 PM
TheDuke17
Mine did the same thing a few months before the rear carrier bearing went out.
It should be painfull to be STUPID!!
TheDuke17 is offline
post #8 of 19 Old 01-21-2010, 08:32 PM Thread Starter
H_Swank
AX-15 is out of a 97 TJ along with the motor. I wasnt sure what the tranny called for, a friend said he ran ATF in his. Plus the seal on the xfer case input if gone, so I figured I would run the same fluid in both.
It dont sound like ujoints, but I guess anything is possible. I will check the tanny mount since I had to fab something up cause the skid plate was for a BA10.
Any suggestions as far as upgraded ujoints?
H_Swank is offline
post #9 of 19 Old 01-21-2010, 08:45 PM
MJMPC
I dont think I would run ATF in a man trans .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #10 of 19 Old 01-21-2010, 08:46 PM
mrmud4x4
I would get a seal in there and drain that ATF out, put in a good synthetic oil or penzoil synchromesh.
jus curious - How does it shift?
mrmud4x4 is offline
post #11 of 19 Old 01-21-2010, 08:52 PM
4.7stroker
There is nothing wrong with ATF in manual trannies. My Mustang T45 has been using ATF for 14 years and my Jeep AX15 has been using ATF for 2 years and both shift just like new.
I would check mounts, all driveline u-joints and pinion angle, I would also check for slop in the bearings of the xfer case and diff.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #12 of 19 Old 01-21-2010, 09:04 PM Thread Starter
H_Swank
It shifts ok. I think it should be better. A little grind going into reverse, but nothing major. I am going to replace the ATF with Sythetic 10W-30. What should I run in the xfer case?
I havent messed with U joints in forever. How can I check them to see if they are the problem?
H_Swank is offline
post #13 of 19 Old 01-21-2010, 09:23 PM
mrmud4x4
The driveshaft ujoints are actually shaped like a cross, they connect the U of the driveshaft with the U of the yoke.
Turn your driveshaft by hand while you hold the yoke steady, see if there is play, any popping/clicking while you rotate shaft back and forth.(jus leave it in gear and on the ground) Also visually look at the "cap" of the ujoint and the cap straps and bolts that hold the straps in place. (small bolts) If the bearings under the cap are worn, there will be play there or a visible gap. The bearings may actually fall out between the cap and ujoint end. There are four bearing caps on each ujoint. At the rearend yoke, two should be strapped/bolted, and two should be held in place at the ends with C-clips.
You'll see, real easy check
mrmud4x4 is offline
post #14 of 19 Old 01-21-2010, 09:23 PM
4.7stroker
Just grab and wiggle, there should be no slop in the joint. The xfer case should be ATF. I have Mobile1 in mine.
Dwayne
[url]
[url]
post #15 of 19 Old 01-21-2010, 09:42 PM
gearhead1985
get the autozone gold for the life time warranty they are decent just make sure to keep them greased
with your vibrations since you used atf not an oil you might of ate up a bearing my input bearing went out and cased the same symptoms
i want to put a pic here but the computer won't let me so here is the link
gearhead1985 is offline
Bad Vibration. Please Help? metal_kid17 YJ Wrangler Technical Forum 8 10-26-2009 03:52 PM
Bad Vibration. Manard TJ Wrangler Technical Forum 3 02-25-2008 06:26 PM
Odd vibration JeepPirate TJ Wrangler Technical Forum 4 01-14-2008 01:03 PM
vibration igolf JK Wrangler Technical Forum 20 12-17-2007 08:26 AM
Vibration henri TJ Wrangler Technical Forum 13 04-13-2005 08:25 AM
