A little flexin - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > A little flexin
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE Shipping Sale!FS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-16-2015, 02:39 PM   #1
WHATDIDIDO
77" This is the first time I've got it measured. How does that compare with other YJ's with a stock wheel base SUA?
WHATDIDIDO is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 02:42 PM   #2
WHATDIDIDO
More pics
Unread 05-16-2015, 03:05 PM   #3
jhrebs
1987 YJ Wrangler
77"? What are you measuring when u say 77"? I am interested only because a couple of people have said mine looks stiff when flexing and I have no idea what they're talking about?
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 03:15 PM   #4
WHATDIDIDO
Don't have any idea, all they a aid was 77" and one of the guys measuring made a comment that it was real good for a leaf spring
Someone on the other board said I should have got a RTI score. Didn't think to ask.
Unread 05-16-2015, 03:15 PM   #5
WHATDIDIDO
This was a front shot when headed up
Unread 05-16-2015, 03:17 PM   #6
WHATDIDIDO
I was trying to compete with this guy. Haha
Unread 05-16-2015, 03:30 PM   #7
timatoe
timatoe's Avatar
Maybe 77" from the end of the ramp? Obviously it's nowhere near 77" of flex, that buggy's not even near that.
Nevertheless, looks like a decent amount of flex.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 03:43 PM   #8
WHATDIDIDO
Originally Posted by timatoe
Maybe 77" from the end of the ramp? Obviously it's nowhere near 77" of flex, that buggy's not even near that. Nevertheless, looks like a decent amount of flex.
I think your right. The rail was 114"
Unread 05-16-2015, 04:02 PM   #9
The_Goob
Hell on Wheels
The_Goob's Avatar
usually the ramp s 20 or 30*, they measure how far up the ramp you got lengthwise, then plug in your wheelbase and the degree of ramp into a calculation to get the rti score. if you know your wheelbase and what degree ramp that is you can get your score still. I never bothered to get mine cause I kept driving up and lifted pass side tire a foot off the ground
The_Goob is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 04:02 PM   #10
Drednot
Drednot's Avatar
Your ramp travel index (RTI) for that ramp would be about 824. Distance traveled up the ramp(77"), divided by your wheel base (93.4"), times 1000.
You can only compare between ramps with the same angle. Some are 15 degrees, 20 degrees or 30 degrees.
Stock SUVs are around 400-500
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 04:07 PM   #11
WHATDIDIDO
Haha me too, I didn't realize I was suppose to stop when the rear wheel came up. So I kept going till the Jeep felt light in the rear. Im new to these ramps so live and learn I guess. Haha
Thanks for all the replies guys. I had a blast today seeing all the different set ups.
Unread 05-16-2015, 04:15 PM   #12
The_Goob
Hell on Wheels
The_Goob's Avatar
my rear never lifted it was the front the rear tire was starting to go up the ramp
Unread 05-16-2015, 04:20 PM   #13
WHATDIDIDO
That would have been a cool sight and picture 😄
Unread 05-16-2015, 04:30 PM   #14
WHATDIDIDO
Wonder what I can do to get more flex without going SOA. I still have my trac bar in the front. I know if I remove it, that will help. Any other thoughts?
Unread 05-16-2015, 06:07 PM   #15
mark1305
mark1305's Avatar
Stupid question dept: When everyone talks about removing the track bar, especially in the front. Does that refer to the sway bar, or in the old terminology the panhard bar that runs diagonally almost parallel to the steering drag link?
mark1305 is offline   Reply With Quote Quick reply to this message
