Quantcast listing top halves, doors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > listing top halves, doors
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-05-2009, 10:42 AM   #1
texas_yj
Senior Redneck Member
texas_yj's Avatar
my driver side door top (1/2 doors soft top) doesn't sit tight at the belt line, and sits cockeyed to the window and b pillar, the passenger door fits right. is there a way to ajust the fit of the soft top panel, or any mods you have done. I thought about threading the pins and putting a nut on each to raise the pin out of the seat after the window belt line is installed. the pin recepticles are still tight, is there an adjustment at the bottom of the insert? I do pull the windows off often.
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) 99 TJ 5.0 mustang GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT on MB Chaos 5s, superlift 6" RR long arm, D30/44 w/ ARBs & yukons, warn bumpers, custom sliders, Mile Marker winch - work in progress!
texas_yj is offline   Reply With Quote
Old 03-05-2009, 12:41 PM   #2
ziebartrob
Are any of the "pins" that go into the top of the half door bent?
ziebartrob is offline   Reply With Quote
Old 03-05-2009, 04:31 PM   #3
texas_yj
texas_yj's Avatar
don't appear to be, they slide right in without hassle, and apply just alittle pressure to the window seal on the door channels. it I lift up the rear most pin, the door looks square in the frame and the belt draws tight., so the problem is found, the solution is in question????
Old 03-05-2009, 06:38 PM   #4
Burnerman
Maybe you need one of these....Upper door pin insert
89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
Check my Gallery for pics.
My Rebuild Thread
Take a minute and fill out your profile, Please
Burnerman is offline   Reply With Quote
Glock Forum
