AT lines for a heat exchanger ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > AT lines for a heat exchanger ?
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 05-14-2015, 11:25 PM   #1
wrangler4me
Hello all
have a question for anyone that might have done this or anyone's 2 cents. I replaced my radiator with one that has the auto trans cooler on the bottom. I have a 5 Speed so I don't need the trans cooler part. I have been wanting to add a heat exchanger for showers while camping. I was wondering if I could just use the 12v pump to run the water threw the trans. cooler on the radiator and if it would heat the water enough to take the chill out of the mountain water. I hope I made this understandable, it is 1:30 am lol. Thanks for any thoughts or help.
wrangler4me is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 12:22 AM   #2
Anticanman
The Thunder Chunky
Anticanman's Avatar
No more to add. You've got it right on the money.
Luck Favours The Prepared
Originally Posted by rambo3489 View Post
Listen to what the canman says. You don't have to take it all word for word. But at least listen to the man. He knows his ****. Its a no BS straight to the point realistic approach to things. You may not like it. But someday you might have an Anticanman moment. Like you just had. I know I have. Hell I had 2 last week.
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 04:55 AM   #3
Que89YJ
The problem is the exchange time to heat the water. If you had a way of recirculating it until it gets warm it might work but one pass through isn't enough to make a difference in temp.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 09:07 PM   #4
gtg413i
gtg413i's Avatar
2003 WJ
good point. Maybe put a valve in there that when you open it, it goes to the shower head, when you close it, it goes into the recirculation loop and a temp sensor that auto shuts off so it doesn't get too hot.
Brian's Black Betty Build: http://www.jeepforum.com/forum/f197/...build-1270544/
gtg413i is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 08:58 AM   #5
Rebel442
The other issue I foresee is the the 3/8ths line isnt exactly going to flow a river. Your shower will probably be a drizzle.
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 08:59 AM   #6
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Coleman makes a propane hot water on demand unit now....
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 03:36 PM   #7
timatoe
timatoe's Avatar
It would certainly need to recirculate. Even if you simply fed a 5 gallon bucket with a pump to the radiator and back etc with a bypass for a shower head.
All of the water lines in my motor home are 3/8 ID PEX style lines. The shower isn't an at home type shower but it gets the job done no problem.
This would be the way to go. There are also other manufacturers for on demand units for motor homes etc. As long as you're already running a 12v pump pretty much any of them should work.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 04:07 PM   #8
The_Goob
Hell on Wheels
The_Goob's Avatar
if you had a decent sized plastic drum to use as a recirc tank like the others have mentioned, im sure you could get the water a little bit warm. enough to wet down, then lather, then rinse and not leave it running. have it set up to pull from the bottom and feed back into the top, with some sort of ball alve to switch it to the shower when needed.
I like the idea
The_Goob is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 04:42 PM   #9
fishadventure
Originally Posted by The_Goob
... sure you could get the water a little bit warm. enough to wet down, then lather, then rinse and not leave it running... I like the idea
It only takes about 4 gallons for a shower with a 45psi diaphragm pump and a hard spray 1gal/minute shower head for a good long camp shower. Sure, the teens will be miffed they can only go 4 minutes of full flow
Now a jeep is a small thing...you make me think I need to put my '69 Westfalia back together- and lift it!
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline   Reply With Quote Quick reply to this message
Unread 05-16-2015, 06:12 PM   #10
timatoe
timatoe's Avatar
I've seen one of THESE running around here lately, lifted on 33's.
Unread 05-16-2015, 08:02 PM   #11
Anticanman
The Thunder Chunky
Anticanman's Avatar
I just saw one heading up to the snow near slick rock last night. Thing looked pretty beastly. It wasnt on 33's but they are pretty good fire trail campers.
Unread 05-16-2015, 08:47 PM   #12
Chrisnvegas
Chrisnvegas's Avatar
Why not just use a pickup and slide in? They have worked well for years. I'm looking for a slide in for my F350.
Solar showers are cheap and work great. Why not use a solar shower and use a pump to recirculate while the sun helps out too?
People say this one will hit 110 in 3 hours and it's only 30 bucks.
http://www.amazon.com/Advanced-Eleme.../dp/B005CB7XCK
What happens in my Jeep, stays in my Jeep
Chrisnvegas is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 05:54 AM   #13
Mike Romain
We have used those solar shower bags for years on our camping runs. They work very well, but run out fast so we have 2 of them. Handy to have one hanging in the sun by the cooking area too.
Mike
