limited slip or open? - JeepForum.com
post #1 of 4 Old 12-10-2008, 05:34 PM Thread Starter
1993sahara
i think my jeep has open carriers its a 93 sahara, but when i m in mud drivers side front spins n passeneger rear spins. what is so bad about open carriers? also is there a cheap upgrade for limited slip?
93 Sahara 4.0, ax15, BDS 2 inch springs, MORE greasable 5/8hd shackles, Ford 8.8 rear, AA sye, Quigley cv shaft, 32" wrangler mtr with Kevlar
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
1993sahara is offline
post #2 of 4 Old 12-10-2008, 05:40 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
In an open carrier, the power/torque will take the path of least resistance.
In mud, often the traction (or lack thereof ) is about equal & both sides will spin/have power with an open diff.
Joe Dillard is offline
post #3 of 4 Old 12-10-2008, 05:44 PM Thread Starter
1993sahara
should i upgrade
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
post #4 of 4 Old 12-10-2008, 06:00 PM
Joe Dillard
I'd upgrade the front, but pass on spending $ on the D35C.
I suppose it's possible that you already have a limited slip in the rear. It was optional. If it does, it's ~15 years old and more than likely worn out (if you do have one).
You could pull the cover (or, if you are savy remove the filler plug) and take a look inside to see if it's open or factory LSD. A small inspection mirror & light can be used to see if it has an LSD thru the fill plug.
Be advised, those rubber fill plugs are a POS & tear easily & then leak like a siv.
96 limited slip 98 open?????? dallass YJ Wrangler Technical Forum 15 01-21-2010 10:14 AM
anotehr ford 8.8 ? limited slip or open teejmcd YJ Wrangler Technical Forum 11 10-09-2008 09:15 PM
Way to convert open diff to limited slip? WilliamH TJ Wrangler Technical Forum 3 03-07-2007 06:24 AM
Open Diff or Limited Slip??? sdlemaster TJ Wrangler Technical Forum 28 02-09-2007 09:44 AM
open vs limited slip, which is better for offroading ? MeGAMoE TJ Wrangler Technical Forum 13 10-17-2006 11:46 AM
