Limited slip or not - JeepForum.com
post #1 of 8 Old 03-11-2008, 02:35 PM Thread Starter
shinigami
Limited slip or not
does anyone know what models came with a limited slip differential?
Originally Posted by jmathis3 View Post
lots of hair pulling, tool throwing, beer drinking, swearing, and eventualy it will start. haha good luck.
I LOL'd
I.Y.A.A.Y.A.S.
shinigami is offline
post #2 of 8 Old 03-12-2008, 06:42 PM
AZYJJK
My 92 Sahara came from the factory with a limited slip. I used to live in Vista.
AZYJJK is offline
post #3 of 8 Old 03-12-2008, 07:23 PM
timatoe
timatoe's Avatar
Mine also had a factory LSD, it was a base model with the I-6. Of course it could've been ordered that way.
timatoe is online now
post #4 of 8 Old 03-12-2008, 07:45 PM Thread Starter
shinigami
how do i figure out if i have it or not, because i changed the diff fluid and dont know if i need the additive or not.
I LOL'd
I.Y.A.A.Y.A.S.
post #5 of 8 Old 03-12-2008, 09:03 PM
SonofSam02
the easiest and truest way to tell if you have a trac-lok limited slip (the one from the factory) is to open up the rear differential.
If the corner on the carrier opposite of the ring gear are curved, then you have a open carrier,
if they are squarish, then you have a limited slip.
Whether it works or not is a whole nother thing
SonofSam02 is offline
post #6 of 8 Old 03-12-2008, 10:35 PM
jcook1989
Mine is a limited slip. I read somewhere that there was a little metal tag with some numbers on it that means you have a LSD. Mine has one.
jcook1989 is offline
post #7 of 8 Old 03-12-2008, 10:41 PM Thread Starter
shinigami
I know i have a metal tag that is on the ring of the diff cover, i thought that was on all diffs. how important is the friction modifier that im supposed to add?
I LOL'd
I.Y.A.A.Y.A.S.
post #8 of 8 Old 03-13-2008, 01:17 AM
timatoe
timatoe's Avatar
It won't hurt it if you don't have LSD, I'd just go ahead and put it in there.
Limited slip... more like limited thinking 1dirtywhyjay YJ Wrangler Technical Forum 12 04-17-2009 07:08 AM
Anti-Slip / Limited Slip HELP!!! mtb1981 JK Wrangler Technical Forum 3 05-18-2007 07:06 AM
Limited Slip?? Pipedrummer TJ Wrangler Technical Forum 42 04-30-2007 08:21 PM
? about limited slip in D35 cspoffroad TJ Wrangler Technical Forum 11 04-27-2005 05:57 PM
Limited Slip SpitNine TJ Wrangler Technical Forum 5 11-01-2002 06:59 AM
