Limited slip... more like limited thinking - JeepForum.com
post #1 of 13 Old 10-09-2008, 08:02 PM Thread Starter
1dirtywhyjay
#1So forgive me for for being new...
I have an 89 with dana 30's, det. locker front and rear.
I want to change the gear oil. I found the basic answers in the FAQ...
But the addative for limited slip? Sorry for sounding like an office wiener but how do I know if I have limited slip? this thing feels locked up and goes where it wants in 4low.
#2 I want to swap the fan clutch. the ask if i want forward or reverse.
If the fan is mounted behind rad it should be pulling right? reverse?
Thanks.
1dirtywhyjay is offline
post #2 of 13 Old 10-09-2008, 09:03 PM
Brandon_YJ
1987 YJ Wrangler
If you have an LS there should be a badge on the pumpkin stating so.
But you say you have a Detroit locker? That's not a limited slip, that's a locker.
Unless you have an LS made by Detroit of course.
The fan behind the radiator should be pulling. Else the fan would be fighting against the wind entering the front of the vehicle.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #3 of 13 Old 10-09-2008, 09:05 PM
bigredcherokee
Question 1. Your not going to need any addative just 75w-90.
Question 2. take your old one off and bring it to them they can cross ref the number on it.
For those of you in Louisiana visit
bigredcherokee is offline
post #4 of 13 Old 10-09-2008, 09:08 PM
bigredcherokee
Brandon your right, but I believe that its based more on the which way or Water pump is going. Eary I6 had a revers water pump I know this b/c I cracked the head on my 90 YJ b/c the rotation was diffrent.
post #5 of 13 Old 10-09-2008, 09:17 PM
Brandon_YJ
1987 YJ Wrangler
Did you have a serp belt on yours? My 258 has a standard rotational pump on it, I replaced it a few months ago. I have v-belts.
The same as on my old AMC Eagle, v-belt equipped 258 and used a standard rotational pump.
I've never heard of the fan direction being based off the water pump style.
in a (text only)
post #6 of 13 Old 10-09-2008, 09:30 PM
pat8942
pat8942's Avatar
The reason the fan is supposed to draw air from the front is to cool the radiator and engine.
If you drew hot air from the engine into the radiator it would hinder cooling considerably.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #7 of 13 Old 10-09-2008, 09:43 PM
Brandon_YJ
1987 YJ Wrangler
Yeah, that too.
I've still never heard of a fan direction being base on the water pump rotation though.
in a (text only)
post #8 of 13 Old 10-09-2008, 10:23 PM
bigsquat
I know u stated u have a detroit, aussie reckomended that i run a 140 wt in there lockr to quiet it down a little. might not be the same in a detriot but the theory sounds good.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #9 of 13 Old 10-10-2008, 06:58 AM
muddy93
1987 FSJ Wagoneer
Yeah, that too.
stock clutch fan attaches to the water pump.
so if the water pump is reverse rotation, and you put a regular fan on it, the fan will be turning the wrong direction.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #10 of 13 Old 10-10-2008, 01:47 PM
NH2112
Forklifts and other industrial equipment with rear-mounted engines do just that and generally don't overheat.
Phil
'90 YJ w/4.2l & 4.0l head, Weber carb, 5-speed, 4" RC lift, 33x10.5x15 BFG MT KM2s.
NH2112 is offline
post #11 of 13 Old 10-11-2008, 03:24 PM Thread Starter
1dirtywhyjay
thank you for the input. I love this forum!
Thanks KEN
post #12 of 13 Old 04-12-2009, 03:40 PM
242much
2009 JK Wrangler
get a griffin radiator and a set of electrical fans. lol, thread back from the dead.
"The stoke was palpable..."
good grief, just buy the Rubicon.
242much is offline
post #13 of 13 Old 04-17-2009, 07:08 AM
muddy93
1987 FSJ Wagoneer
this is true, and in a trail only vehicle, you might not have any problems setting it up that way.
however, once you got up to highway speeds, and have all that air in front of the vehicle trying come in through the radiator, and the fan trying to push it out, I'd bet that it would overheat.
muddy93 is offline
Limited slip help. Ixiah YJ Wrangler Technical Forum 12 11-06-2008 05:48 PM
limited slip twatsonhd TJ Wrangler Technical Forum 6 05-29-2008 03:02 PM
Anti-Slip / Limited Slip HELP!!! mtb1981 JK Wrangler Technical Forum 3 05-18-2007 07:06 AM
Do I have limited slip in my 00? pamo TJ Wrangler Technical Forum 6 09-11-2006 09:52 AM
limited slip? mrcleanshoes TJ Wrangler Technical Forum 3 09-10-2006 09:40 PM
