like my floor? - JeepForum.com
post #1 of 11 Old 04-26-2010, 05:32 PM Thread Starter
leepster
like my floor?
I cover the floor with rustoluems truck bed coating and then I had some left over strips of diamond plate from a different project, so I cut strips and covered spots in the floor I had previously repaired.
I'll keep my freedom, my money and my guns and you can keep the damn change.
leepster is offline
post #2 of 11 Old 04-26-2010, 05:33 PM Thread Starter
leepster
wow, sorry about the huge pictures, not sure how I messed that up.
leepster is offline
post #3 of 11 Old 04-26-2010, 07:10 PM
Burns95
I do like that... alot. Just curious how often you get BLINDED by the suns reflection
Burns95 is offline
post #4 of 11 Old 04-26-2010, 07:12 PM
stumpjumper09
wow i actually really like that a lot, good job!
Jeep name = White lightnin!
stumpjumper09 is offline
post #5 of 11 Old 04-26-2010, 07:16 PM
dodger889
Give them about a couple of months they won't be so shinny. But hey to everyone has their own taste. This is just my own thoughts I would have put then where my feet would be then just down the middle.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 11 Old 04-26-2010, 07:31 PM
linusb
Does that truck bed lining have the same texture as other products like Hercliner? Yours looks like a smoother texture...which I like.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #7 of 11 Old 04-26-2010, 07:54 PM Thread Starter
leepster
I would have done the whole floor but I didnt have enough plate left, and the reason they are down the middle is because that is where the bad spots I covered up were at.
leepster is offline
post #8 of 11 Old 04-26-2010, 07:56 PM Thread Starter
leepster
I have never used herc, but it is definately smoother than linex bed liner.
leepster is offline
post #9 of 11 Old 04-26-2010, 08:02 PM
linusb
Where'd you buy the bedliner? How much did you need?
linusb is offline
post #10 of 11 Old 04-26-2010, 09:21 PM
dodger889
OK hey then it works for you.
post #11 of 11 Old 04-27-2010, 03:20 PM Thread Starter
leepster
walmart, use about 3/4ths of a gallon for 2 coats.
leepster is offline
What should I do to my floor kalik99 YJ Wrangler Technical Forum 8 02-18-2009 03:06 PM
Floor Rot? FireLAB JK Wrangler Technical Forum 4 03-08-2008 06:46 PM
hot floor? 92redyj YJ Wrangler Technical Forum 1 07-11-2006 03:55 PM
wet floor skp94yj YJ Wrangler Technical Forum 2 07-16-2005 03:50 PM
wet floor lokua TJ Wrangler Technical Forum 11 07-12-2005 04:46 PM
