Light wiring question? - JeepForum.com
post #1 of 13 Old 11-29-2011, 07:31 AM Thread Starter
rockcop
Before I get flamed, I've searched and can't find the answer to my question. I have two auxiliary lights on my front bumper that were installed by the PO with no switch that I can find. I want to rewire with a switch on the dash. I only want to turn the lights on manually. Can I wire these lights straight to the battery and through a switch? Do I need relays and a inline fuse? Any recommendations is appreciated.
rockcop is offline
post #2 of 13 Old 11-29-2011, 07:35 AM
loukimball
yes, I have mine that way, I used inline fuse, I mounted a switch under dash...if you run more than 2 u Prolly need to do relays and go through fuse box...
Sent from my not so smart phone using JeepForum
what would leatherface do?
loukimball is offline
post #3 of 13 Old 11-29-2011, 07:36 AM
tdewit
Here's a good write-up with diagrams.
http://www.google.com/imgres?imgurl=...ed=0CBkQ9QEwAQ
tdewit is offline
post #4 of 13 Old 11-29-2011, 08:53 AM
Old4X
1990 CJ7
Relay use depends on wattage of the lights. If high output, use a relay.
ALWAYS fuse EVERY accessory!
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 13 Old 11-29-2011, 10:58 AM
Billsbluejeep
Always use a fuse... period!
...and you might as well wire it up with relays too, that way when you modify or replace the lights you won't need to go back and retrofit your wiring too.
Here's a good write-up for doing it right; http://www.jeepforum.com/forum/f20/w...ations-378268/
Billsbluejeep is offline
post #6 of 13 Old 11-29-2011, 11:05 AM
timatoe
timatoe's Avatar
Can you? Yes. Would I? No.
What I did was get a relatively cheap fuse block that is fed from the battery and then every accessory is fed from there through a relay. It's not expensive or difficult to do.
This is what mine looks like. I know it's a mess, I plan on cleaning it all up a bit when I do the new fenders etc. this winter....
timatoe is offline
post #7 of 13 Old 11-29-2011, 11:18 AM
Shenandoah
Some states require the lights wired to come on with the low/high beams. Check your state laws (for on road use).
I would recommend relay(s) and always fuse. I bought some black, plastic boxes from Radio Shack. In line fuses were put inside one box and relays were put in the other box. Boxes are marked and harnesses are run between them.
Timatoe has the same idea, mine is less high tech.
Turn a wrench, save a tree
Shenandoah is offline
post #8 of 13 Old 11-29-2011, 12:06 PM
Xpress
^Link to list of these laws? The only laws I have heard is that if they are accessory offroad lights that they need to be covered up while on the road.
All about that unibody life.
Xpress is offline
post #9 of 13 Old 11-29-2011, 01:34 PM
Berniebikes
Sometimes lights require much more amperage (hence bigger wire, more power) than tyical switches are usually made to handle. Rather than run from the battery into the cab, thru a switch and back out to a light you use a relay. It only takes a very low current to run the relay, so your relay switch leg goes from the cab and thru the relay. That way your higher power wire is confined and you don't overload your switch. As others said, also use a fuse to prevent melting things! Whether inline, or thru a fuse block doesn't really matter, just protect it. If you need assistance on how to do it the link above has all the info you need!
Berniebikes is offline
post #10 of 13 Old 11-29-2011, 01:51 PM
timatoe
timatoe's Avatar
I'm unaware of any such wiring law in CA. The way yours are from your avatar pic are fine, anything more than four lights total have to be covered.
timatoe is offline
post #11 of 13 Old 11-29-2011, 02:17 PM
Matt The Hammer
The relay eliminates all the power flowing through your switch on the dash. The relay acts like a switch that is controlled by the switch on the dash. It's actually much easier to use the relay as the wiring is much easier to run IMO.
2013 JKU
1995 YJ
Matt The Hammer is offline
post #12 of 13 Old 11-29-2011, 02:22 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If you're setting up more than one set of lights, I would suggest a fuse block like Tim has, for power from battery to relays and one hot wire daisy chained to the input of all your switches with cat 5 out to the relays to energize them. It minimizes the birds nest under the hood.
Luck Favours The Prepared
Anticanman is offline
post #13 of 13 Old 11-29-2011, 03:07 PM
Shenandoah
Don't know about CA law. In Va you can have 4 lights on at a time. Low beam plus another set wired into the low bean and high beam with another set wired to high beam.
Off road lights have to be covered and they can be wired to a separate switch.
02 fog light wiring question ImNotStuck TJ Wrangler Technical Forum 28 05-16-2012 07:35 PM
Fog Light Wiring question BobKnake TJ Wrangler Technical Forum 8 07-19-2010 02:46 PM
Light Bar Wiring Question clerks37 YJ Wrangler Technical Forum 1 06-08-2010 05:18 AM
Fog light wiring question for my LJ yj_ryn TJ Wrangler Technical Forum 3 06-17-2006 01:58 PM
Light Bar Wiring Question Nighthawk TJ Wrangler Technical Forum 5 06-24-2002 06:31 AM
