Quantcast light and defroster on hardtop - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > light and defroster on hardtop
Old 12-21-2005, 05:33 PM   #1
dwales31
today i was looking at how to hook up my defroster on ym hardtop and saw what needed to be fixed on it...then i noticed that there is a light for the inside which i dont know how but i hadnt noticed until then. after breaking the stubborn cover it revealed an empty spot for a bulb....i can make everything work if i only had the wiring harness....anyone know where i can get one? or will i have to make one.
dwales31 is offline   Reply With Quote
Old 12-23-2005, 12:47 PM   #2
dwales31
any help anyone?
Old 12-23-2005, 12:53 PM   #3
that_1_guy
Try dealership....sorry, not too familiar with the hardtops. Good luck tho!
'94 [COLOR=Red][B]Red[/B] [/COLOR] YJ
4-banger (2.5L) 5sp/3" bl with 31" bf/mt
[COLOR=Red]/l ,[____],
l---L –0lllllll0-
[COLOR=Black]()_) ()_)--o-)_)[/COLOR] [/COLOR]
[COLOR=Red][B]Red Jeep Club Member #318[/B] [/COLOR] | [COLOR="Navy"][B]Low Output 4-Banger Club Member #46[/B][/COLOR]
that_1_guy is offline   Reply With Quote
Old 12-23-2005, 01:31 PM   #4
brundz
just make it...take the positive and negative from the wiring harness on the hardtop and run them to the positive and negative behind the light under the dash...then that light will come on when the under dash lights go on.
brundz is offline   Reply With Quote
Old 12-23-2005, 09:53 PM   #5
93Renny
I have a hard top I put on in the winter. The jeep has a harness in the back driver side corner that hooks to the hard top harness for the brake lite, wiper, and dome lite. Does your jeep have this harness?
If so then your home free, just run the wires down through the HT and to that harness. Use a test lite to see which one is positive when the door is open.
If not, then probably not worth your while. Just depends on how baddly you want a dome lite.
1993 Jeep Renegade, 4.0 I6, 2.5 Rubicon Express Lift kit, 1 inch Shackles, BFG 32x11.50x15
Other add ons, TJ style Stainless hood catches, custom tow hitch......
93Renny is offline   Reply With Quote
Old 12-25-2005, 02:07 PM   #6
rare-renegade
On the same line...I had the rear light also and wanted to upgrade the light output. I ended up going to Advance Auto and buying a interior light and hooked it up. Very bright to almost blinding! Hooked it up to the + and - wires. Hopes this helps.
1991 Renegade, 4" Rough Country Lift, 32" A/T's on 15x8 Canyons, Fr. Runk Bumper, Rear Warn Rock Crusher Bumper, Ramsey 6000# Winch, 4.10 YJ Axles, Blower Mtr. Upgrade, 150 AMP alternator, ZJ Rear Disc Brakes w/Corvette MC, CB w/Firestik, Half Hardoors, Warn Steering Box Guard, KC Highlights.
rare-renegade is offline   Reply With Quote
Old 12-27-2005, 02:05 AM   #7
YJtank
You could find the hardtop wiring harness on e-bay. However, if you go through the stealer-ship you need the part number which is 82202499. I am in the same position as you are and getting the same bit myself. Hope I helped.
YJtank is offline   Reply With Quote
Glock Forum
