lifting my jeep -
post #1 of 3 Old 09-12-2011, 04:06 PM Thread Starter
lifting my jeep
The front differential went in in 95 Rio grande, I got a hole new front end from my buddys parts jeep, I want to lift it while I have it all apar, my buddy wants me to just make new longer leaf spring shackles, like he did with his jeep, is this safe? And what else would have to be done with brake lines strearing parts?
Thanks ,
millis1 is offline
post #2 of 3 Old 09-12-2011, 04:51 PM
It depends on how much lift you want. For lifting by shackles, don't go above 1.5in lift, which should be no longer than 7in total, in fact that maybe too long, I hope someone validates that. But lifting by shackles with worsen your bump steer. If you have the money to do a proper lift, then go ahead. OME and BDS are the best on the market, stay away from rough country. Many things go into lifting. What type of lift do you want to do? 2.0, 2.5, 3.0,3.5,4+ in.
Collin89Sahara is offline
post #3 of 3 Old 09-12-2011, 06:08 PM
First pick a tire size, what kind of wheeling do you do? If it has alot of axle articulation you need to account for that. But if it is a DD and only ocassionaly sees offroad then a smaller lift with a bigger tire should be alright. But then pick a lift for how much room you need to tuck your tires, I'm looking to go with a BDS, 2.5in lift with 32s, but first I need to do something with that under powered 2.5L, I want to swap in something else first to spin the bigger tires and hopefully be able to keep it as a normal DD. But start with a schackle lift, their cheap, easy, and expandable, meaning that when you buy those schackles they'll work with any suspension you decide to run.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
In order to be able to post messages on the forums, you must first register.
lifting my jeep johnjohnoakes TJ Wrangler Technical Forum 21 01-22-2011 09:23 PM
Lifting My Jeep please help MBC TJ Wrangler Technical Forum 18 01-16-2010 07:14 PM
lifting my jeep need help jeepin08123 TJ Wrangler Technical Forum 17 10-15-2007 10:16 PM
Lifting my Jeep, please help me! ;) kenski83 TJ Wrangler Technical Forum 24 01-07-2005 04:07 PM
Jeep Lifting drzima TJ Wrangler Technical Forum 2 07-06-2004 01:50 PM
