Lifting the body off the frame - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Lifting the body off the frame
All Bilstein shocks & struts - Lowest Prices Ever and TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROCRuffstuff Axle Simple Swap Kit!
Unread 03-29-2015, 07:27 PM   #1
wizekrakr
I am looking to lift the body off the frame of my 89 YJ. I have a hoist and straps to do this with. Can I lift the body with straps on the roll bar and the bars that go to the windshield frame without damaging any sheet metal?
wizekrakr is offline   Reply With Quote Quick reply to this message
Unread 03-29-2015, 07:43 PM   #2
Joe Dillard
Electric Chair Operator
Assuming the tub & windshield frame isn't overly rusted - you should be okay.
Joe Dillard is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 11:58 AM   #3
HaskiE
HaskiE's Avatar
I think so. I've seen forklifts carry around whole (junk) jeeps at the junkyard this way...goodluck!
#theneverendingaxe
HaskiE is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 12:57 PM   #4
mike134
You could always run the straps under the body as well if you are worried about the roll cage not being strong enough in tension. I'd put two heavy duty straps laterally underneath and a strap connecting the two at the very center bottom just to make sure they don't slip off the ends. Wood padding to help keep it from squeezing soft spots.
Or give the roll cage a shot and let us know how it works so I can do the same someday
mike134 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:04 PM   #5
HaskiE
HaskiE's Avatar
I gutted all the interior out of my tub and just lifted it with 4 guys. two guys can do it if you can see where the heck you are going lol
goodluck!
#theneverendingaxe
Unread Yesterday, 04:47 PM   #6
scoopys-yj
when i did my body lift I lifted each side by the bars above the doors
95 yj , 32" swampers, 2.5 ome 3/4 shackles, 1" bl, full cage,
98 tj little above stock
scoopys-yj is offline   Reply With Quote Quick reply to this message
