Lifting - JeepForum.com
post #1 of 4 Old 02-02-2005, 07:01 PM Thread Starter
Yoink
Lifting
It's a stupid question but it's the only one I've got now. When shimming the axles to compesate for whacked out drive line angles, do you only have to shim the rear axle or will I need to shim the front as well. I think I already know the answer is only shim the rear but I want to be sure. Also wish me luck, installing this weekend.
'95 YJ SE - I6 4.0L, 2" BDS, 1" Shackle Lift, 2.5" BL, 31X10.50 A/T's, Herculined (Work In Progress)
AIM - XDemiG0DX42
Yoink is offline
post #2 of 4 Old 02-02-2005, 07:05 PM
YJ_Aaron
There are circumstances that require shimming the front. But most lifts dont' require it.
91 YJ rebuild! Rush to get it driving/wheeling.
YJ_Aaron is offline
post #3 of 4 Old 02-02-2005, 08:34 PM
Mr. Notorious
For 90% you don't need fronts because the driveshaft is 3 times as long as the rear. I believe front shims would be used in an allignment situation, irrelevant to driveshaft vibes.
1992 4.0HO 5spd -- BDS 3.5" lift -- 33x11.5 M/T's -- Gibson Cat-Back -- 8.8 with 4.10's -GONE
1967 FJ, linked, 350 chevy, 35's, arbs, blah blah...
2002 TJ
"If you're not moving ahead, you're falling behind"
Mr. Notorious is offline
post #4 of 4 Old 02-02-2005, 08:37 PM
YJ_Aaron
Only reason to run them in the front is to correct caster if it gets out of whack.
YJ_Aaron is offline
lifting my 88 88wrangleryj YJ Wrangler Technical Forum 5 03-19-2007 10:38 PM
lifting a TJ Bobz007 TJ Wrangler Technical Forum 7 12-27-2006 09:23 AM
new to lifting cotoole TJ Wrangler Technical Forum 10 10-10-2006 02:39 PM
Lifting the JK Roadtrip JK Wrangler Technical Forum 9 10-04-2006 04:40 PM
lifting? StuckInMud94 TJ Wrangler Technical Forum 1 05-29-2006 11:51 PM
