Lifters didn't do it, Plaese advize - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Lifters didn't do it, Plaese advize
Unread 07-01-2010, 08:14 AM   #1
Zutroy
Motor had a little rattle (258). Over a week it became a full on banging. When I remove the rocker and rod from the intake side of #2 cylinder it stops. Changed lifters, rocker and rod. Still there. Valves look good. Piston and ring look good. What do I do?
Zutroy is offline   Reply With Quote Quick reply to this message
Unread 07-01-2010, 11:35 AM   #2
MJMPC
Maybe a bad lobe on the cameshaft?
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote Quick reply to this message
Unread 07-01-2010, 11:53 AM   #3
Louie4
I second the camshaft. We rebuilt the top end of my buddies 258 and it was still popping out of the carburetor. We put in a camshaft and lifters and all was good. Generally if you replace the lifters and rods it's good to go ahead and put a new camshaft in.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
258 inline 6 , camshaft
