lifter noise - JeepForum.com
post #1 of 3 Old 06-16-2001, 07:24 AM Thread Starter
djyj
lifter noise
88yj i've fixed in past years by addeding mistery oil for 15min.car had 8,000mi on it first time,2nd time 30mi and it went away.now 88,000. can't be fixed with mistery oil.i know it's colaped. quick fix needed can anyone help. i have 88,000. miles on it now.
djyj is offline
post #2 of 3 Old 06-16-2001, 04:45 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Umm .. I think that I am missing something here. You have/think you have a busted up lifter? Fixing it with mistery oil?? What is that kind of fix?
All Jeep engines have a little problem with the oil pump .. not enough pressure to reach the back cylinders properly. Adding oil will raise the level and allow a better supply.
If your lifters are going, its fairly easy to get at them .. just remove the valve cover and check them. Took me about 1/2 hour to clear the way to remove the valve cover (only to find I had bent rods).
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 3 Old 06-21-2001, 04:04 AM
solid
I just replaced the lifters on my 89 yj...I had to remove the head to do it...
solid is offline
Lifter noise? omgwtfbbqcopter TJ Wrangler Technical Forum 12 02-10-2010 08:39 AM
Difference between Lifter noise and exhaust noise? CAPCDT388 TJ Wrangler Technical Forum 7 11-10-2008 09:31 PM
How Can You Stop Lifter Noise twokids YJ Wrangler Technical Forum 21 06-28-2008 10:42 AM
4.0l lifter noise chadjones99 TJ Wrangler Technical Forum 1 07-27-2004 02:25 PM
Lifter noise NoSpin YJ Wrangler Technical Forum 10 02-24-2003 08:00 PM
