Lifted YJ height? - JeepForum.com
post #1 of 14 Old 09-15-2013, 09:28 PM Thread Starter
TexasPigHunter
Lifted YJ height?
I have a 1993 YJ and have a 4 inch lift not installed, also have 34 inch tires. My garage door is 7feet high. Will this combo for under garage? HOA says no vehicles 6 years or older can be parked in driveway overnight.
TexasPigHunter is offline
post #2 of 14 Old 09-15-2013, 09:36 PM
droopypillow
1987 YJ Wrangler
Yeah. You'll be fine
droopypillow is offline
post #3 of 14 Old 09-15-2013, 09:42 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Just gotta make sure the 4 inch lift will for the 34" tires.
Luck Favours The Prepared
Anticanman is offline
post #4 of 14 Old 09-15-2013, 09:50 PM
crackedcornish
no vehicles 6 yrs or older?...that makes absolutely no sense. I bet my 25 year old YJ looks and runs better than my neighbors beat on and neglected 5 year old POS Hyundai
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #5 of 14 Old 09-15-2013, 09:52 PM
krawler510
That's kind of a comical rule.
My jk with 35s and a 3.5" lift fit so I'm sure a yj would easily.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #6 of 14 Old 09-15-2013, 09:56 PM
waite334
I have 33s with 4in lift yj fits with some room to spare so should work
waite334 is offline
post #7 of 14 Old 09-15-2013, 10:00 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
But these are 34's and swampers usually run tall. Plus not all 4" lifts are created equally.
post #8 of 14 Old 09-15-2013, 10:02 PM
squarelite
My sprung over yj with a total of 7.5" of lift on 35" boggers clears my 7' garage with 28 psi in the tires. It also has a cage that's slightly taller than stock.
squarelite is offline
post #9 of 14 Old 09-15-2013, 10:02 PM Thread Starter
TexasPigHunter
I'm installing a RC 4 inch, and running 34 inch swampers
post #10 of 14 Old 09-15-2013, 10:04 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You'll need more lift than what rough country will be able to provide in a couple months' time.
post #11 of 14 Old 09-16-2013, 12:23 AM
Xpress
You have a **** HOA.
You should fit just nicely, make sure your CB antennas are off though, or are shorties.
All about that unibody life.
Xpress is offline
post #12 of 14 Old 09-16-2013, 02:28 AM
lutzke21
6.5" of lift with 35" tires and I've got 3-4" to spare... You'll be fine.
My Jeep increases the value of property around it... Neighbors be chargin' admittance and ****.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #13 of 14 Old 09-16-2013, 08:19 AM
jaycal3
Im thinking that RC made the HOA as well! Its all crap... thats quite a pretentious rule. Anyway, I dont think you will get a true 4" of lift, and if you do it wont last long. Plus, I wouldnt run your tires at full pressure anyway.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #14 of 14 Old 09-16-2013, 02:51 PM
95YJRusso
if you really have problems, you can always air down the tires to get in and out for that extra inch of clearance you'll need. that wouldn't be too bad if its only a weekend trail rig and not a DD
Had I known Jeeps were going to be this addicting, I probably never would have bought one!
95YJRusso is offline
