lift/tire dilemma - JeepForum.com
post #1 of 10 Old 09-08-2004, 12:23 PM Thread Starter
Varsity Tyler
Varsity Tyler's Avatar
lift/tire dilemma
alright - 93 Renegade with 250 000 kms/150 000 miles
Currently it sits on a set of 30x9.5 Kumho AT. The rims are the stock Renegade ones, 15x8 I think. (pic: http://public.fotki.com/VarsityTyler.../poser_04.html)
On flat (not negative) leaf springs front and back can I fit 31x10.5? I don't do hardcore trails - the Jeep is used mostly on pavement with the odd unassumed logging road and beginner trail thrown in. Flex isn't important. Rubbing at full steer is a minor concern. I think the backspacing is okay. Will they work?
I don't want to lift if I don't have to (read: I can't afford to lift it). If it turns out that I needed a tiny bit of space, would a small shackle lift help?
1993 Renegade 4.0
- 31x10.5 AT rubber on Gamblers
- Limited slip rear
- Bestop bikini, tonneau and windjammer
- Smittybuilt euros
- Custom rear hitch
- Bosch lighting
- CD/iPOD deck, speakers and sub by Kenwood
Varsity Tyler is offline
post #2 of 10 Old 09-08-2004, 12:35 PM
93Sahara
93Sahara's Avatar
Do you already have the 31s? If you don't just go with the 30s, but otherwise a small shackle lift will get them on.
97TJ, 31s, BB <---- current project,
93 YJ Sahara, Lifted, Locked, and Sold
02 VW GTI 1.8T ---His
04 Pontiac Vibe ---Hers
93Sahara is offline
post #3 of 10 Old 09-08-2004, 12:43 PM Thread Starter
Varsity Tyler
have the 30x9.5 now. the tread is gettin low, so I figure that when I get new ones I might as well get something slightly larger if I can.
1993 Renegade 4.0
- Limited slip rear
- Smittybuilt euros
- Custom rear hitch
- Bosch lighting
post #4 of 10 Old 09-08-2004, 01:11 PM
prossett
prossett's Avatar
Location: The oasis city of Al Ain, where the red sand dunes of the UAE meet the craggy mountains of Oman
Nice rig! I say the 31s will just fit, given you don't mind a bit of turning rub and don't need to flex often.
I'd say go for the 31s, and if they really don't fit, put in a shackle lift. I just put in a 1.25" shackle lift and would recommend it: added clearance and a smoother ride.
International Jeep Club, Member No. 1 - Canadian living in the United Arab Emirates
White Jeep Club Member 33
prossett is offline
post #5 of 10 Old 09-12-2004, 12:47 PM
YeepJeep
31's will fit without a problem, I ran 31's on a flat leafed 89 with very little problems, and the renny came stock with 30's so another inch wont be a problem
Renegade Jeep Club member #1
Red Jeep Club Member #230
93 red Renegade, 2.5" lift, 31"Baja Claws, with more to come.
"It's a RENEGADE thing.... you wouldn't understand"
YeepJeep is offline
post #6 of 10 Old 09-12-2004, 01:43 PM
PBjeepster
Hi guys,
I'm having a similar dilemma, I have an 87 YJ, I'm running w/ no lift and 30 x 9.5 Bridge stones...
I would like to get a 2" shackle reversal, the go to 31's or 32's x 10...
Right now i have rubbing w/ a full turn, but only on the left side, so the reversal will fix this, tapped an oddly placed "parking stop thing". I heard that if i get the 10's I'll have rubbing and that spacers are bad... I'm not going to do any heavy off raod, just to the hard to reach paintball fields after the rain and such, so I would like to know if doing the 2" reversal is a good idea and if i go to the 10's how would I get rid of the rubbing w/ out spacers, if the are bad.
Oh one last thing... if i go w/ 32's do i have to get it regeared to keep the same speed and beter milage?
This is my first jeepo so please bear w/ me..
BTW, I have read alot of the posts here and you guyys have been very helpful in the past.
thanks,
Mike
PBjeepster is offline
post #7 of 10 Old 09-20-2004, 12:26 PM
PBjeepster
Originally Posted by PBjeepster
Hi guys,
thanks,
Mike
Anybody? I'm getting my other truck out of the shop and i would to get the Jeep in for the 2" lift and the orderthe tires and rims... trying to budget time and $
post #8 of 10 Old 09-21-2004, 03:07 PM
phlex234
phlex234's Avatar
if you do shackle reversal you need new front driveshaft and i t messes with steering not 1000% sure, it moves axle forward
HI, my name is phlex234 and i approve this message because it's my destiny
Jeep 2.5 Low Output club member #2
92 Red YJ, 3.5 Bds lift, 1" body lift, 1" motor mount lift, 33 in tires, long travel DT3000 shocks, m.o.r.e. 3/8 boomerang shackels, 4:56 gears, Tj flares, rock-it man front and rear bumper, Terraflex SYE and Tom Woods CV driveshaft, herculined tub, custom homemade rocker panels, powered by the almighty 4 cylinder
phlex234 is offline
post #9 of 10 Old 09-21-2004, 04:26 PM
PBjeepster
^^ Thanks... I'll look into that.. I don't want to get caaught w/ having to spend money I'm not aware of when I drop it off!
post #10 of 10 Old 09-22-2004, 06:54 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I'd say you could comfortably run 31s with some extended shackles if they rub stock. For 32s you could probably fit them with the shackles and maybe a 1" body lift if you don't want to spend too much.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
My Tire Dilemma.. FourbyFour TJ Wrangler Technical Forum 11 08-02-2009 03:55 PM
Tire dilemma tecumsa Wrangler General Discussion 5 07-20-2009 12:57 AM
Tire dilemma. 33's on a 98 TJ Sport? dbdraggin TJ Wrangler Technical Forum 14 07-28-2008 07:24 PM
Lift/Rack/Tire Carrier Dilemma MrKleen TJ Wrangler Technical Forum 4 04-25-2007 08:21 AM
Tire Dilemma Kentuckyarms TJ Wrangler Technical Forum 4 08-29-2005 08:54 PM
