lift/t-case question - JeepForum.com
post #1 of 9 Old 10-09-2008, 08:51 AM Thread Starter
whitie_08
i saw the thread about vibs, and got to thinking. i dont exactly know what the transfer case is, is it the transmission shifter, the 4x4 shifter, both or what? so i believe if i understood this, then i would also be able to understand what everyone means by the vibs after the lift, and the tc drop kits etc.
my lift is going on saturday, my cousin [mechanic] is putting it on, and ill be there to do the b!+(h work. So i just want to understand all this stuff.
thanks
whitie_08 is offline
post #2 of 9 Old 10-09-2008, 09:18 AM
MLJeeper
MLJeeper's Avatar
the transfer case is the aluminum box the drive shaft is going into, it connects to the tranny. When we say transfer case drop, we really mean dropping the entire transmission/tc skid plate. Sounds hard but its very easy. 6 bolts, 3 each side. TC drop kit will have a spacer of some type, could be rail, could be pucks and longer bolts. Put a floor jack under the center of the skid plate for the tranny/tc and loosen all the bolts. lower it down the distance of your tc drop, probably 1 ", put the spacer in and the longer bolts and tighten up.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #3 of 9 Old 10-09-2008, 09:25 AM Thread Starter
whitie_08
thank you very much.
post #4 of 9 Old 10-09-2008, 11:09 AM
jeepdude1987
1987 YJ Wrangler
You would be better off with a Slip yoke eliminator though. And depending on your lift you may end up really wanting one it you go off-roading much. I would suggest you read the FAQ and maybe some of the other stickies.
1987 Wrangler YJ RED 4.2 5-speed, NP231, BFG 31x10.5R15 AT/KO on 15x8 gambler wheels.
Caution!!! Under construction!!!!!! Caution!!!
Finishing a 4.0 Cyl.head swap, Just got an AX-15 NP231J combo to replace the busted t-case and craptacular BA10/5. Adding Nutter bypass. Probably more to come before it is back as a DD!
jeepdude1987 is offline
post #5 of 9 Old 10-09-2008, 11:12 AM
brewer
just to clarify - when I look at the manual for removing the T-case - it states to drain fluid and put case in neutral before removing.
From how I read this, I am merely disconnecting the tranny / t-case from the flywheel, and thus not needing to drain fluid / place in neutral?
Or is the case drop just a method of dropping that big metal skid plate that the t-case is attached to?
Beauty is but a lightswitch away :D
brewer is offline
post #6 of 9 Old 10-09-2008, 11:12 AM
brewer
ps - doing my lift install tonight after school... got my nice big shiny new 33s yesterday and they are pirty :P
brewer is offline
post #7 of 9 Old 10-09-2008, 11:38 AM
jeepdude1987
1987 YJ Wrangler
Your just lowering the skid so that your t-case is closer to the original height above the rear axle pinion.
post #8 of 9 Old 10-09-2008, 11:41 AM
brewer
sweet - thanks
brewer is offline
post #9 of 9 Old 10-09-2008, 12:26 PM
bigsquat
brewer, its good that your asking questions and trying to gain knowledge before u jump in.We are all in different stages of or jeep journey. And some day you will be giving advice to some other young apprentice.Good luck and enjoy!
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
NP231C/J transfer case - Case Question Kelvinator YJ Wrangler Technical Forum 5 09-28-2009 11:35 AM
231 transfer case question cherokee case in a tj? 472cid TJ Wrangler Technical Forum 5 06-11-2009 09:39 PM
T-case Shifter Bracket upgrade w/ T-case drop and body lift 04<TJ>renegade TJ Wrangler Technical Forum 1 04-05-2009 06:08 PM
I want a lift, but no T-Case drop. Umm... YJ Wrangler Technical Forum 3 07-01-2005 07:52 AM
Transfer case kit/ Lift Kit Question pablo_max TJ Wrangler Technical Forum 11 07-07-2004 04:01 PM
