lift suggestions - JeepForum.com
post #1 of 10 Old 02-15-2013, 09:18 AM Thread Starter
kodiak1
lift suggestions
I am doing a 4 inch spring lift on my yj. Should I go with a tranfer case drop kit or a sye??
kodiak1 is offline
post #2 of 10 Old 02-15-2013, 09:20 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Which lift? You'll how to see how it works on the jeep first.
Luck Favours The Prepared
Anticanman is offline
post #3 of 10 Old 02-15-2013, 09:38 AM
DAjeep88
Depends on your budget to do it right go with sye but you can get away with t-case drop
DAjeep88 is offline
post #4 of 10 Old 02-15-2013, 09:52 AM
Irongrave
why 4 inch springs 2 inch spings shackles and a small body lift will be a much better package. you can tummy tuck the t-case and gas tank and get better travel out of the lower lift height springs. IMO t-case drops are worthless wastes of time why lift a rig to lower your belly clearance
Current
2002 WJ 2wd DD
Irongrave is offline
post #5 of 10 Old 02-15-2013, 10:14 AM
StanF
Originally Posted by Irongrave View Post
snip...IMO t-case drops are worthless wastes of time why lift a rig to lower your belly clearance
Agree with you 100%, but it could be used as a temporary solution to stagger upgrade costs...
StanF is offline
post #6 of 10 Old 02-15-2013, 10:30 AM Thread Starter
kodiak1
OK I already have a 4 lift that was given to me, so that is why 4 inch. Currently my jeep has a negetive lift as the stock springs are shot and actually bow down. I agree with the belly clearance the whole reason for a lift is to RAISE it up not lower a drag point. I was only asking because this is my first lift and I value my fellow jeepers opinions. Is a sye needed for the angle on the drive shaft or will I be able to get away with stock? OR will I have to put the lift on and then see what the angle is??
kodiak1 is offline
post #7 of 10 Old 02-15-2013, 11:04 AM
giggityjeeper
for the most part this...... you will mnost likely need a SYe to properly do it.... as stated u can get away with a tcase crop for now..... SYe runs around 350.....
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #8 of 10 Old 02-15-2013, 12:00 PM
140mower
There is a third option, you can also add a 1" motor mount lift to get the required angle. It's the route I plan to take next, I used some 1 1\4" scrap tubing as a temp. t-case drop until I can get them made up and installed. An sye is probably going in soon as well, as the benefits far out-weigh the cost imo irregardless of the lift height. I've begun the hunt for an 8.8, which should (will) seal the deal.
If it wasn't done the hard way, I didn't do it.
140mower is offline
post #9 of 10 Old 02-15-2013, 03:21 PM
jokerchief462
Before you get to far into spending $$$ take a look at the pics and then plan what you need to get the pinion angle correct. It can be done with or withou shims, T-case drops and MMLs. All depends on how she sits after the lift and you go to line up the shaft take a look at the pinion angle. Once you have that figured out you are good to go. and then how to get to the pinion angle you need. I inserted both the standard two joint (stock) shaft and a double cardan shaft for the SYE install.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #10 of 10 Old 02-16-2013, 09:50 AM
RockWoRM
RockWoRM's Avatar
I generally say do the HD SYE on any lift over 3". Why? Not so much b/c is is absolutely necessary, but b/c the YJ slip yoke is crap. And a HD SYE is the better way to go IMHO and you'll have a better/stronger Jeep b/c of it.
$.o2
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
