Lift shackle - JeepForum.com
post #1 of 13 Old 01-19-2012, 12:39 PM Thread Starter
Rhino92
Lift shackle
I've got a 92 yj and I am thinking about doing a 2" shackle lift to give me more tire clearance. My stock fender flares rub on the 31x10.50. Has anyone done this and are there any thing I need to pay close attention to. I would be leaving everything stock except for the shackles.
Rhino92 is offline
post #2 of 13 Old 01-19-2012, 12:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
A 1" shackle lift will clear 31" tires. Try also cutting your fender flares with an exacto knife
Luck Favours The Prepared
Anticanman is offline
post #3 of 13 Old 01-19-2012, 03:57 PM
WakeDoctor
2" is way too much shackle lift.
WakeDoctor is offline
post #4 of 13 Old 01-19-2012, 04:30 PM Thread Starter
Rhino92
Ok. I am looking at upgrading to some 33 inch tires. So can you explain why 2 inches is to much.
Rhino92 is offline
post #5 of 13 Old 01-19-2012, 04:33 PM
dillonjm
2013 WK
It rotates the axle throwing the driveline angles and steering geometry out of whack. The longer the shackle, more the rotation and this the more out of spec your steering gets.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #6 of 13 Old 01-19-2012, 04:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
2 inch shackles throw off the castor angle of the axle. That's the imaginary axis that your wheels pivot. It will cause terrible bumpsteer and you'll wish you wouldn't have installed them. Trust me. 1" is the limit.
You can do a 1" body lift with your 1" shackle lift and do some serious cutting on your fenders and possibly be able to fit 33's.
post #7 of 13 Old 01-20-2012, 08:44 AM
CRASHNDENT
Depending on your experience level and budget.....you have some options.
I'm currently running 33's with absolutely no rubbing or clearance issues and i did 3 easy mods.
First was (some people hate it) a 2" body lift. I personally like BL's because it allows me cheap clearance and ability to get to almost anything to work on it.
Second was TJ flares. I like the look of them and it really opens up the wheel wells allowing even more clearance.
Third was the "S-10 Bastard Pack" mod. This one is a little more labor intensive. My springs were flat and lifeless. My jeep rides so much better now and it gained me another 1.75 to 2" of lift. you may or may not have to do a T-case drop or Slip yoke eliminator with this one.
These are the things i did to my YJ and i'm pretty happy with the performance. You can find all the answers you need and some you didn't know you needed here..... http://www.jeepforum.com/forum/f12/y...s-here-580536/
Hope this helps at least some.
Don
CRASHNDENT is offline
post #8 of 13 Old 01-20-2012, 03:59 PM
mekken
Don't do it. I bought them thinking they were a cheap lift and wound up with broken rear springs from the stress on them. If that wasn't enough the ride was horrible. Like others said i wouldn't go higher than 1". It's goofy as hell looking to. This lasted about a month before I bought a rc lift kit cause of the springs. look how far foward the rear wheel is. the foward spring eye snapped on both springs's shoving the whole axle foward.
mekken is offline
post #9 of 13 Old 01-20-2012, 04:37 PM
NHfireLJ
NHfireLJ's Avatar
1" shackles, 1" BL Trim the flares....
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #10 of 13 Old 01-20-2012, 05:24 PM
superj
DUDE!!!! that is a badass parking job!! look at those skid marks, right in to the slot.
the second picture ruins the cool skidding effect of hte first picture though because of hte tire tracks under the jeep
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #11 of 13 Old 01-20-2012, 05:48 PM
bigbossd1030
So a person can do a 1" shackle lift with absolutely no mods what's so ever. No drops including pitman arm etc? Or ds angles?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #12 of 13 Old 01-20-2012, 05:59 PM
dillonjm
2013 WK
Correct. 1" lift, regardless of way obtained doesn't require a DPA or t-case drop.
dillonjm is offline
post #13 of 13 Old 01-20-2012, 06:17 PM
wayno32m
wayno32m's Avatar
x 2 Thats what i did for the 31"s then I could`nt stop it`s a DISEASE next is the 8.8 sitting in the garage !!!!
wayno32m is offline
