Quantcast Lift Questions - E-brake bracket + Pics of the lift so far! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Lift Questions - E-brake bracket + Pics of the lift so far!
Old 07-25-2008, 09:46 PM   #1
tommanns
Hey all,
Well, the 4" lift is coming along nicely, and today officially marks the end of the front end. I've run into a bit of a snag on the rear though... specifically, with the brake and e-brake lines.
The regular brakes, I do have an extension for, and plan to install it.
The e-brake on the passenger side was easy enough to accomodate, as I just bend the bracket that holds it to the middle of the frame, and easily freed up enough line.
However, the driver side e-brake is where I run into problems, as I can't simply move the line around due to it's shorter length. I do have an e-brake relocation bracket. It's pictured below, highlighted in blue..
My main question is - how do I install this? I bought my lift kit used and don't have any instructions. Does anyone have a write-up or link to instructions from Skyjacker or otherwise?
Oh! and does anyone know what the part highlighted in red is? I'm thinking track-bar relocation bracket, but it just looks strange... any ideas?
Also, I've included some pics of the lift so far, let me know what you think! I finially got some 33" BFG AT's on there today and I think I'm in love
THANKS AGAIN JF!
The question pic:
Before shot of the front end, on 225's:
After the 4" lift!... on 225's :
After 4" lift, on the new 33's :
Sorry for the poor pic quality, I'll have more up as soon as I'm finished!
lllllll
tommanns is offline   Reply With Quote
Old 07-25-2008, 10:20 PM   #2
ar4130
1997 XJ Cherokee
These install instructions are for a Rough Country kit, but if you look at page 5 it shows a picture of a similar bracket installed and explains how to mount it. http://www.roughcountry.com/install/620S.pdf
I'm pretty sure the other piece is a track bar relocation bracket.
(Somebody jump in here if I'm wrong)
If it is, just throw it out, along with your track bars
Here are the skyjacker instructions, but they're not that good.
http://skyjacker.com/image/search/pdf/YJ40.pdf
1992 YJ -2.5 Old Man Emu lift, RC 1-1/4" Boom greasable shackles, JKS Discos, 1" Daystar BL, 33x12.5x15 BFG AT KO's mounted on 15x8 Cragar soft 8's, flush mounted tailights, SJFab front bumper, TKH Fab swingout tire carrier welded to a Dirtworx rear bumper, Tuffy stereo console, RC SS Extended brake lines, Home brew plate relocation bracket, Magnaflow Cat, Dynomax Cat back, No track bars front or rear
1997 XJ - 4.5 RC coils + extra OEM spring isolator(6.5" actual front), OME medium duty springs+OME extra leaf + Teraflex 1.5 shackles (6.5" actual in rear), OME Long travel shocks, OME SS, IRO Adj TB, IRO Adj LCA'S, IRO Adj Uppers, RC Control arm drop brackets, JKS Quicker Discos, SYE / XJ shaft, 33x12.5x15 BFG AT KO's on 15x8 Cragar soft 8's, RC SS extended Brake lines, Hella 500's
1996 ZJ - RE 2 inch BB w/shocks (rides like crap), OME SS, 31x10.5x15 General Grabber AT2's - SOLD
ar4130 is offline   Reply With Quote
Old 07-25-2008, 11:03 PM   #3
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
ar is right, trac bar relocating bracket, or more accurately, a trac bar rasing bracket. junk. throw it away IMO.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Old 07-25-2008, 11:34 PM   #4
tommanns
Thanks for the link man... damn RC is alot more thorough than Skyjacker on their installation instructions... still though, it looks like this bracket is for the standard brake lines... any ideas on what to do for the e-brake?
lllllll
Old 07-25-2008, 11:35 PM   #5
tommanns
Oh and don't worry about the trackbars, consider them gone.
lllllll
Old 07-25-2008, 11:45 PM   #6
leftlanetruckin
XJ on 37's
not able to back off the adjusting nuts and have enough room?
i dont run an e brake myself, just another PIA to me
would have thought that either buying a new longer cable, or backing off the adjusting nuts would work ok though.
also, off memory, the yj cables run through the frame. maybe try to pull them throught the frame and run them underneath the frame rail?
martin
http://www.jeepforum.com/forum/showthread.php?t=324622
Choose wisely!
Old 07-26-2008, 12:19 AM   #7
Kool2BSquare
1987 YJ Wrangler
I had no trouble installing the 4" kit , the e-brake cables were plenty long as is on mine.
And yes the RC instructions are awesome as is their tech people should you have to call them.
I'm not convinced that junking track bars on one that sees street duty is such a great idea though, just my opinion.
Kool2BSquare is offline   Reply With Quote
Old 07-26-2008, 01:06 AM   #8
tommanns
Ahh thanks for the tip man, good to hear there's at least one thing I won't have to worry about...
As for trackbars, we'll see... I currently have yet to put those or the swaybars back on, but as soon as we're up and running I'll test it out and see if I'll survive.
Again, thanks for the tips guys.
lllllll
Glock Forum
