***-Lift Questions-*** - JeepForum.com
post #1 of 3 Old 03-06-2002, 05:59 PM Thread Starter
letsgojeep
Hi, I have a 1995 YJ Wrangler. I am looking to do a 3" body lift with 1.5-2" shackles and run 32x11.50x15"s. Does anyone have any idea how much the body lift & shackles will cost? Also, are there any pics out there with this setup?
letsgojeep is offline
post #2 of 3 Old 03-06-2002, 06:56 PM
Capa
Well if you bought good shackles all around, and a good body lift you will probably spend
110 or so for a body lift and 150 for shackles. Instead of spending 260, at least buy the RoughCountry 3" lift for 379.
You still get your 3 inches, it's a lil more money, but you lift it the right way.
Capa is offline
post #3 of 3 Old 03-06-2002, 10:01 PM
Atropine
Atropine's Avatar
I second that notion
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
Body lift, Motor mount lift questions Hoofguy TJ Wrangler Technical Forum 15 07-06-2012 05:22 PM
Body Lift and Motor mount lift questions RYANR97 TJ Wrangler Technical Forum 12 08-31-2008 01:31 PM
Lift Questions - E-brake bracket + Pics of the lift so far! tommanns YJ Wrangler Technical Forum 7 07-26-2008 12:06 AM
Questions regarding Body Lift and Motor mount lift ToddEdge TJ Wrangler Technical Forum 5 11-26-2007 12:52 PM
Suspension Lift, Body Lift Questions CityJeep TJ Wrangler Technical Forum 2 06-12-2005 03:52 PM
