lift questions - JeepForum.com
post #1 of 9 Old 04-10-2013, 07:17 PM Thread Starter
djhrn1
lift questions
A question regarding lifts????
I just finished putting a 4" RE spring lift on my 1990 YJ, it also has 6" shackles and 3" body lift which I don't think the body lift has anything to do with, but when I took it out for a ride I noticed a drive line vibration more when take your foot off the gas then when accelerating. I noticed that my rear drive shaft out of the transfer case about 1 to 2" further than what it was before. I believe this is probably the culprit, but my real question is. Do I need to install a SYE or could I go with a newer double U-joint drive shaft or do I need both??? Building on a budget you know
Thanks Dave
djhrn1 is offline
post #2 of 9 Old 04-10-2013, 07:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You have 5" of lift which always necessitates a slip yoke eliminator and a double cardan driveshaft. They always come as a pair.
Fear not, they can be had quite cheaply. If you can find a 90's Cherokee or early 90's grand Cherokee, steal the front driveshaft and have it cut and balanced to the specs you'll need by measuring. The SYE is only $160 and is easy to install. You just need a good pair of snap ring pliers, some basic hand tools and some patience. And an ability to comprehend the English language. That's it.
Luck Favours The Prepared
Anticanman is offline
post #3 of 9 Old 04-10-2013, 07:57 PM Thread Starter
djhrn1
Thanks Antican:
The search is on, but a question, is the drive shafts your referring to on the 90's Cherokee/Grand Cherokee double cardan???
Thanks Dave
djhrn1 is offline
post #4 of 9 Old 04-10-2013, 08:23 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yes they are. I wouldn't point you in the wrong direction.
post #5 of 9 Old 04-10-2013, 10:14 PM
Sparrows
True dat^^^
I got my CV XJ shaft for like $15.00 from a pick and pull yard. It's another $65-75 to have it cut and balanced. Not a bad deal!
Cheers
June '13 YJOTM
Sparrows is offline
post #6 of 9 Old 04-10-2013, 10:56 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Are you still planning on running those 31" tires (with ~8" of lift) in your profile with that amount of lift?
If so, you've got a unique sense of balance.
Joe Dillard is offline
post #7 of 9 Old 04-10-2013, 10:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Its cheaper than regearing
post #8 of 9 Old 04-11-2013, 10:42 AM Thread Starter
djhrn1
Go Big
No as soon as I finished I looked at it and said looks like bike tires on there (lol). Sad part is my 31 Pro Comps are brand new. Ya know anyone willing to trade down. I'd like to go to at least 35's. I live in central Pa. Next step is a Lokka for the front diff.
djhrn1 is offline
post #9 of 9 Old 04-11-2013, 10:47 AM
Sparrows
Ditch that 3" BL man. That's crazy too much BL. Drop down to a 1" Daystar.
Put your tires on CL. I bet they sell quick. Where I live, good MTs sell fast and for nearly new prices. That or post up an ad for a trade and see what happens.
Cheers
June '13 YJOTM
Sparrows is offline
