Lift questions - Page 2 - JeepForum.com
post #16 of 25 Old 02-09-2013, 01:35 PM
jeepyj13
Originally Posted by Northinger View Post
I did look at their 2" and 4" im lean more towards the two inch. Im thinking thats the way to go. With that being said whats needed for the 2" lift, do i need to drop the tcase change drive angles or what?
On a 2" lift you may get away without a tcase drop. Some springs come with shims to tilt rear axle toward the tcase hoping to correct the driveline angle. Although some spring companies use the same spring for front and rear applications so you have to order shims separately. It would not hurt to get a drop because most good springs tend to lift jeeps alittle higher than advertised height.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #17 of 25 Old 02-09-2013, 02:44 PM
Chrisnvegas
Chrisnvegas's Avatar
OME come with shims already installed. Still had a slight vibration. I noticed the slight vibration killed my fuel mileage as well as not good for u joints. I experimented with different size transfer case drops. I was able to use 1/2 inch spacers and it got rid of the vibration completely. I don't like spacers though, so a SYE is in my future. And you are right, I got more than 2.5 inches of lift.
BAN COMPUTER UPDATES!
Chrisnvegas is offline
post #18 of 25 Old 02-09-2013, 03:37 PM
jeepyj13
Yeah when my 4" rc spring were still 4" springs everytime I took the hardtop off I got nasty driveline vibrations to a point I did end up blowing a ujoint. I have a drop and shims now and got rid of vibrations when the rc springs sagged. Since replacing the springs though the vibs came back. I will have to invest in a sye kit myself.
jeepyj13 is offline
post #19 of 25 Old 02-09-2013, 10:30 PM Thread Starter
Northinger
So I think I will eventually get the zone 2" lift. As for these vibrations, is it possible to get that without any lift? My shifter in gear had a ton of vibration and almost rocks front to back slightly
Northinger is offline
post #20 of 25 Old 02-09-2013, 11:00 PM
djwrangler
1997 XJ Cherokee
Sounds like you have bad motor and/or trans mounts.
djwrangler is offline
post #21 of 25 Old 02-10-2013, 03:57 AM
mike_breaker_5
i havn't heard anyone ask yet.
what size tires are you planning on running, 33"s?
prothane 1" taller body mounts (not 1" lift pucks, these are full 1" longer mounts) $150
1/2"-1" lift shackles. $75
add a leaf from a junkyard s-10 $25 (depending on the salvage yard this should give you 1"-1.5".) or 2.5" lift springs $400.
zj front driveshaft from same salvage yard $25 (make sure it's one with the double cardan joint)
SYE kit $200
buddy that's is capable of not screwing up cutting the DS to length and welding it back together $0
this will get you a decent start on getting 33"s under your jeep, minus the price of the tires and rims of course.
if you are daring and don't mind using a sawzall on your tub...
get some used tj rear flares, cut the tub to accept them, put on a set of tube front fenders, and you will definitely have room for 33"s possibly 34"s or 35"s. that is if you do this in addition to what i suggested above.
i have never been a huge fan of boxed lifts. i did all of the above to my jeep except the s-10 add a leaves, which is probably in my future. i went spring over and cutting of the body to fit 37"s.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #22 of 25 Old 02-17-2013, 07:11 PM Thread Starter
Northinger
How can i tell if the trans mounts are bad?
post #23 of 25 Old 02-17-2013, 10:05 PM
jokerchief462
Take a pry bar and see how much movement you have. Or drop the skid and remove and see if the rubber is separating.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #24 of 25 Old 02-18-2013, 09:28 AM
giggityjeeper
QUOTE=Northinger;14935107]Okay so before I get bashed by everyone and their mother on this topic, yes I did search this forum as well as google. I could not find the exact questions Im asking, if you do please by all means point me in that direction, but I would rather have MY questions answered before spending the money.
Anyways I am considering getting a RC lift, I've heard many mixed opinions of them. This will be a daily driver aswell as light play in the woods. Im pretty much stock now so anything I can do now i don't really ask more from the RC as far from aesthetics. Im currently running 30" but don't plan on going bigger than 31's. I heard so many things, but being on a budget, this is in my price, but i don't want to waste money on crap. Ive heard they didn't do well as far as flex, I'm not looking for crazy flex, but I do want a somewhat smooth ride. Ive also heard they sag easily, but some people say they don't. Im only really loading up with a hardtop, spare tire, and winch.[/QUOTE]
really cause Iv only heard bad reviews, even ppl who say its not 'that bad' still cant say its good, or even decent
like everyone said OME or BDS, i run OME...
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #25 of 25 Old 02-18-2013, 02:11 PM
Rproject
1987 YJ Wrangler
Been there, done that. Spent 6 months researching before I pulled the trigger on my OME lift. DAMN GLAD I DID! Best lift I've ever put on, seen, or ridden on. Bar none!
I did a transfer case drop just because I didn't want to risk a driveshaft disconnect (been there too). It was cheap insurance.
As for price, I don't know where you're coming up with $1,000+ for OME. I was under $800 through Morris 4x4 - complete.
4 - springs (approx $100 ea)
4 - shocks (Rancho RS5000 - approx $50 ea)
1 - steering stabilizer (Rancho - approx $50)
4 - OME bushing sets ($30 a spring)
That's $770 for the whole setup (plus transfer case kit and shipping)
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
