Lift Questions - JeepForum.com
post #1 of 4 Old 12-16-2011, 10:46 PM Thread Starter
RebelBlood
Lift Questions
I might be getting a set of 4" superlift lift springs as part of a trade for a truck I have, but it's ONLY the springs. What all else would I need to put the lift on?
My YJ already has a 3" body lift, what all would I have to change if I just added the suspension lift?
Thought about taking the body lift off and putting the suspension on, but not sure I want to do that or not.
I've never done anything when it comes to lifts, (my YJ had the body lift when I got it) so I have no idea how hard putting it on would be. Any and all help/advice would be greatly appreciated.
RebelBlood is offline
post #2 of 4 Old 12-16-2011, 11:40 PM
jeepyj13
you will need new ubolts, new shocks to compensate length(stock shocks too short), possibly a drop pitman arm. if you choose to keep swaybar get some swaybar disconect links if not ditch them. ditch the tracbars too. thats the bar that connects to frame to axle. on leaf spring yjs they are not needed as the springs themselves are strong enough to center the axle. you will need brakeline extension brackets or just buy longer lines. a transfer case drop kit you will need to compensate for driveline vibs if it has any. trust me you will feel what a driveline vibration feels like. if you got the $ buy a sye kit and new driveshaft. how hard to put on a yj lift? not difficult at all if you have the right tools. the really lengthy part sometimes considered hardpart is taking all the stock old stuff off as the bolts could be rusted and may require cutting off which is time consuming. when i did my yj lift most of the old stuff came off except ubolts, and frame to spring bolts and swaybar links.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #3 of 4 Old 12-17-2011, 01:07 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
And axle shims.
Luck Favours The Prepared
Anticanman is offline
post #4 of 4 Old 12-17-2011, 01:54 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Cruise a few YJ suspension sales websites and take a look at the parts lists (some are more complete than others) also take a look at the install instructions.
Joe Dillard is offline
Body lift, Motor mount lift questions Hoofguy TJ Wrangler Technical Forum 15 07-06-2012 05:22 PM
Body lift questions: Most complete kit, 1/2 or 1" lift, alum vs poly Fargo TJ Wrangler Technical Forum 25 11-07-2011 07:41 AM
Lift Questions? Tire Questions john304 JK Wrangler Technical Forum 8 01-20-2011 07:31 PM
Lift Questions - E-brake bracket + Pics of the lift so far! tommanns YJ Wrangler Technical Forum 7 07-26-2008 12:06 AM
Questions regarding Body Lift and Motor mount lift ToddEdge TJ Wrangler Technical Forum 5 11-26-2007 12:52 PM
