lift question - JeepForum.com
post #1 of 27 Old 06-12-2013, 08:34 AM Thread Starter
92yjjeeper
lift question
I have a yj with 3in body lift and 1 1/4 shackles. I want to add a suspension lift to it. 1 is it possible and 2 I'm planning to price the lift on a cheap budget. What would I need I already have 4in lift leaf springs what else do I need?
92yjjeeper is offline
post #2 of 27 Old 06-12-2013, 08:41 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
This question has been asked so many times and the answers are always the same.
Do a search then you will be able to ask more detailed questions.
The two things you need to answer first are:
1. What is your goal for the lift
2. What size tires are you wanting to run
Answer those and you will start getting some good answers.
-John-
johnboy68 is offline
post #3 of 27 Old 06-12-2013, 08:44 AM
rogerv
^^^^ my thoughts also ! Look through the FAQ's, lots of great info there.
If it's not broke- modify it, so it won't break
rogerv is online now
post #4 of 27 Old 06-12-2013, 09:20 AM Thread Starter
92yjjeeper
Sorry guys I'm new to the site..I'm running 33x12.5x15..don't really have a goal as I do not drive it much just a little offroading here and there I just want to go higher
post #5 of 27 Old 06-12-2013, 09:39 AM
rogerv
"92"- welcome to the best forum on the interweb. You will find many folks here with a vast amount of knowledge. The more you read and educate yourself, well, just start reading. Sure, we all get stumped occasionally, owning a jeep is a learning experience and a life style.
Always remember- safety first. before adding more height to your ride, is it ready for it ?
post #6 of 27 Old 06-12-2013, 11:07 AM Thread Starter
92yjjeeper
Well the leaf springs needs to be replaced they are flat so I figured since I need the leaf spring I should just lift it
post #7 of 27 Old 06-12-2013, 01:35 PM
NonRubicon
It is possible, but you do realize that all this combined will make for 8.25" of lift? IMHO, that is hella stupid high for only 33" tires on a vehicle that doesn't see much off roading. The 4" springs alone would fit the 33" tires, and look more proportional and have a more stable center of gravity.
My suggestion: Put in the 4" suspension lift, ditch the huge body lift, and ditch the huge shackles. Be prepared to do a slip yoke eliminator and CV driveshaft, extend brake lines, and optionally install a sway bar disconnect.
NonRubicon is offline
post #8 of 27 Old 06-12-2013, 03:44 PM
Rproject
1987 YJ Wrangler
The part that scares me is the "on a cheap budget" part.
OP, while I can appreciate being fiscally responsible, cheap lifts are cheap for a reason. When you put lift springs on you also need to replace the bushings (typically not included) and put on longer travel shocks (also not included). For 4" lift springs you also need a drop pitman arm to keep the steering geometry correct as well as a transfer case (tc) drop or Slip Yoke Eliminator (SYE) kit and a new Constantly Variable (CV) rear drive shaft. If you don't put in a tc drop when you do a 4" lift, you WILL have a rear drive shaft disconnect sooner than later. The SYE kit and CV drive shaft eliminate the need for the tc drop giving you greater under belly clearance. Also, when you lift that far, your brake lines will now be too short to allow slack at full flex. The axles are stronger than the brake lines. When flexing on the trail, you have the potential to blow a brake line creating a very dangerous situation.
The "all inclusive" kits are rarely that. They're also rather vanilla in their components. The best way to lift is to piece a system together based upon what you plan to do, where you plan to go, how you plan to wheel and what size tires you will eventually be running.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #9 of 27 Old 06-12-2013, 07:54 PM Thread Starter
92yjjeeper
If I just replace my worn out leaf springs..how.much extra will it bring the jeep up? The leaf springs do have to be replaced cause they are flat.
post #10 of 27 Old 06-12-2013, 08:10 PM
Rproject
1987 YJ Wrangler
You'll likely get 1/2-1" of lift just by replacing springs, but you're still going to have to replace the bushings. Don't forget the bushings. Crown makes the OEM replacement spring.
1996 White ZJ
Rproject is offline
post #11 of 27 Old 06-12-2013, 08:11 PM
xrunndonex
1994 ZJ
It should lift it like a inch or so is what I'm thinking
xrunndonex is offline
post #12 of 27 Old 06-12-2013, 08:17 PM Thread Starter
92yjjeeper
Yea I was planning on doing the bushings for the springs also. Funny thing is my uncle just put a 4in skyjacker lift and he has 33s I just want to be higher then him again. Thats my main goal lol
post #13 of 27 Old 06-12-2013, 08:26 PM
Rproject
1987 YJ Wrangler
Beat him with your skill. Although, if you have the original springs, the 3" body lift and 1 1/4" shackles aren't helping you.
1996 White ZJ
Rproject is offline
post #14 of 27 Old 06-12-2013, 08:33 PM Thread Starter
92yjjeeper
I just need that extra little bit. We are about even height even if I'm a hair taller that's all that matters ha..hopefully yous can understand were I'm coming from. We both do a lot of ball busting
post #15 of 27 Old 06-12-2013, 09:06 PM
britrider
My advice, if you're on a budget and this is (likely) your daily driver: buy another jeep that's already lifted and sell yours. You'll never get out of your jeep what you put into it, and I am seeing (in my area, at least... KC, MO) lifted YJs for between 4-6k. Assuming your jeep is not a pile, you should be able to get about 3500-5k out of it, depending on condition. Sell it, and buy one that's had the parts thrown at it. Let me repeat, this is ONLY if you're truly on a budget and want a bigger jeep.
The thing I can't square is, if you're on a budget, then the bigger you go, the more expensive it becomes to operate and maintain your jeep. I assume you've thought this through.
If selling your jeep is not an option, then as others have said, ditch the pos body lift, get a set of 4" springs, and be prepared to spend the dough on new shocks, new front (and probably rear) brake lines, and a weekend's worth of work putting it all together. You can probably get by with the stock rear driveshaft, if you don't do a lot of off-roading.
Best of luck to you.
britrider is offline
