To lift or not to lift???? - Page 2 - JeepForum.com
post #16 of 35 Old 10-04-2013, 06:03 AM
Siva283
Originally Posted by Rynfw100 View Post
You can get 4 - 36R (Heavy Duty) OME springs for ~$500 shipped and they ride great. I fit 32's fine and have tons of room for flex. Stock U-bolts will reach fine, just depends how boogered they are. It's the brake lines you have to worry about.
You may or may not need a t-case drop... but if you do, do it yourself. There are plenty of write ups on how to do your own. If you're lazy like I was, I bought the Skyjacker t-case drop for $40.00.
I hear good things about Bilstein 5100s, and I'm going to order some once my Jeep gets on the road again.
DO NOT REUSE U_BOLTS. When torqued correctly they stretch a little. Reusing them can cause catastrophic failures like stopping and the watch your axle go by you
Ask me how I know...
Siva283 is offline
post #17 of 35 Old 10-04-2013, 06:25 AM
Rproject
1987 YJ Wrangler
I don't know about that. I reused mine and haven't had a problem. Lift has been on almost year. Nearly 10,000 road miles and over 100 wheeling hours on 'em since the lift and they're just fine.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #18 of 35 Old 10-04-2013, 06:28 AM
Siva283
I would say you are lucky. I would risk my safety over $30 worth of U-Bolts though
Siva283 is offline
post #19 of 35 Old 10-04-2013, 07:19 AM
nzpete
What is your reference for this?
By definition the torquing of a bolt stretches it a bit. True torque is measured by length to determine tension, but it is not always possible, so we measure bolt tightness in leu of.
To me, RC is kind of the Harbor Freight of springs. Sometimes you get a good deal and sometimes you don't.
nzpete is offline
post #20 of 35 Old 10-04-2013, 07:48 AM
Siva283
My reference is common sense mixed with the way we trat other highload hardware. When you stretch a bolt torqueinging it the first time you are doing what it was designed for. But when you then restretch it torquing it the second time the metal will start to fateage and get weaker and weaker. Not to mention those u bolts are normally rather old on top of it. I would rather spend the $30 and be safe than sorry. Dont agree with me thats OK you know what they say about opinions mine included and we all have one. If I wasnt at work I would look for some facts but I am feeling lazy on this friday morning.
Siva283 is offline
post #21 of 35 Old 10-04-2013, 07:32 PM
DirtKar
Maximum Effort
DirtKar's Avatar
'Clamping force is reduced by over 55% even though the reading on the torque wrench is identical. The importance of using new U-bolts and nuts with lubricated threads is essential to maintain required clamping forces.'
http://www.plazafleetparts.com/uploa...100/ubolts.pdf
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #22 of 35 Old 10-04-2013, 07:44 PM
Rproject
1987 YJ Wrangler
Wow, a vendor of u-bolts recommends replacing them, what a shock!
There is a flaw on the second page, "reused u-bolt with dry and damaged threads." Who says that the threads on all currently installed u-bolts are dry and damaged? Mine came off with a 3/4" box end wrench. If they were dry and/or damaged, they would have required air tools, heat or other means of "force" to remove them. Now, if you have to heat them to get the bolts off, YES, REPLACE THEM, because you've compromised the integrity of the metal by heating it.
1996 White ZJ
Rproject is offline
post #23 of 35 Old 10-04-2013, 08:18 PM
DirtKar
Maximum Effort
DirtKar's Avatar
^^^ Fair enough.
That was the first search result I came across when looking into what I've always considered a no-brainier. I'm sure that with a bit more effort a very overworded technical reason could be had. To each his own... I will be replacing mine in a week when I install my new springs. The way I see it, they've done thier job for 20 years and it's time. Much less technical reason.
YJOTM JULY 2014
DirtKar is offline
post #24 of 35 Old 10-05-2013, 12:24 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You compromise the integrity of the steel theads by torquing it.
Ubolts are always to be changed. Think of them as underwear of the jeep: when you put your jeep through enough excitement to necessitate changing the springs, wouldn't you want to change your underwear too?
It is a drop in the bucket for cost compared to the suspension price.
Anticanman is offline
post #25 of 35 Old 10-05-2013, 03:04 AM
Siva283
Glad to see I am not the only voice of reason on these.
Siva283 is offline
post #26 of 35 Old 10-06-2013, 02:26 PM
nzpete
Ridiculous.
Certainly, there are times when new hardware may be called out in service manuals, but in this case even the factory manual doesn't call for U-bolt replacement. In fact, it doesn't even call for replacement of the U-bolt nuts.
Your description of repeated torquing, and "getting weaker and weaker" is also incorrect.
Of course, there is nothing wrong with replacing U-bolts and nuts every time one removes that hardware, but it is a waste of money.
If you don't have one, I would suggest a factory manual for your year Jeep. Not only for safety, but it can save money.
nzpete is offline
post #27 of 35 Old 10-06-2013, 03:46 PM
Siva283
Ridiculous. Certainly, there are times when new hardware may be called out in service manuals, but in this case even the factory manual doesn't call for U-bolt replacement. In fact, it doesn't even call for replacement of the U-bolt nuts. Your description of repeated torquing, and "getting weaker and weaker" is also incorrect. Of course, there is nothing wrong with replacing U-bolts and nuts every time one removes that hardware, but it is a waste of money. If you don't have one, I would suggest a factory manual for your year Jeep. Not only for safety, but it can save money.
I have a manual just because it doesn't expressly say certain things doesn't mean you shouldn't do it. Things have come a long way since the 90's. Ridiculous I think not.you torqued it once and stretched it. Now your torquing again and stretching it more. It's like when you bend a paper clip back and fourth. Eventually it breaks and doesn't take that long either. You can do whatever you want. I for one will not be telling someone to reuse certain items wear failure can result up to and including death. If you can't do it right you shouldn't being doing it until you can. Sent from one of my electronic toys using JeepForum
Siva283 is offline
post #28 of 35 Old 10-06-2013, 04:00 PM
Rproject
1987 YJ Wrangler
Everything depends on condition. Do you replace hoses because your radiator fins got clogged with mud? If they're cracked - yes. If not - why? IMHO, it's the same with u-bolts. If they look almost new, why replace them? If the threads are all rusty and the nuts look like crap, replace them.
1996 White ZJ
Rproject is offline
post #29 of 35 Old 10-06-2013, 04:22 PM
Siva283
rad hoses worse case scenario over heAt and seize the engine. U-bolt snap and it gets ugly. I don't know about you but I think superman is the only one that can see metal fatigue. By the time you can see the metal fatigue is beyond unsafe. With the stress's we put on parts wheeling and crap there is no margin for error with items like this. The fsm might not say replace then but every after market lift kit comes with bolts if you get just the springs the instructions say don't reuse the ubolts. The old ubolts would fit the replacement spring in most cases but they still tell you to replace them. Go get factory replacement springs from the dealer they tell you to replace them. So basically all updated info since the fsm was printed says not to reuse ubolts. Are you noticing the pattern yet?
Siva283 is offline
post #30 of 35 Old 10-06-2013, 05:13 PM
nzpete
No, what you mean to say is:
"just because it doesn't expressly say certain things doesn't mean you "CAN"T" do it."
If it makes you feel better to replace, then by all means replace, but you're going to spend a lot of money replacing things that don't need to be.
Me, I'm going to read the manual and if there is no call out that specifies replacement, I'm going to re-use, provided that the item is in satisfactory condition.
nzpete is offline
lifts , wheels
