LIFT ON LIFT SOA - JeepForum.com
post #1 of 11 Old 05-10-2002, 02:03 PM Thread Starter
bigjeep39
bigjeep39's Avatar
LIFT ON LIFT SOA
can you get an put a 4" springs on top of a SOA, i wanted to do that here soon because i have to small of jeep. I want to also do a shackle reversal is that going to be big enough to put 36" tires??
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 11 Old 05-10-2002, 03:35 PM
Keith Strong
<img src="http://www.imagestation.com/picture/sraid20/p1dbb3e0de1c91d722761370ada30d20f/fdbf93c2.jpg" alt="" />
36's? I can fit 40's if I wanted to. Total as seen here is about 12 inches of lift. THose are 38's
Which lever do I pull?
Keith Strong is offline
post #3 of 11 Old 05-10-2002, 03:41 PM
Keith Strong
Couple more for you
<img src="http://www.imagestation.com/picture/sraid17/pcf50d6beb1da9e0469558accd22a0a49/fdf74b88.jpg" alt="" />
<img src="http://www.imagestation.com/picture/sraid20/pfb6a1d6e836f931c98333f7a1b0ebb3b/fdbf93e1.jpg" alt="" />
post #4 of 11 Old 05-10-2002, 04:03 PM
jeep_fun
I wanna do the same thing. What did you have to change?steering, angles, etc. thanx
Adam "Drasko" Draskovich
yellow '91 YJ
2.5L, 4" lift, 33x12.50 TSL Radials
4.56 gears(both ends)
and a 350/TH400/Dana 300/Dana 44/Dana 60 coming soon
jeep_fun is offline
post #5 of 11 Old 05-10-2002, 05:02 PM
Keith Strong
There are a few things you need to doo
D44, rev cut, high steer with Hydraulic Ram assist
D60, at 24 degree pinion angle
T18 tranny, Atlas II
If you are going to try and do it with stock stuff....be prepared fro problems. First off, you will GRENADE your D35c rear with 38's. second, with stock tranny and tcase you will have major issues with your drive shaft. It will be too short, and at too much of an angle. You will ABSOLUTELY need an SYE, but I wouldnt advise that much lift for stock stuff. Also, you will GRENADE your D35c with 38's. Steering on the front requires an s'd drag link or tons of money to do high steer on a D30. You should replace the 30 with a 44 or 60 that has flat top knuckles for hi steer. Have I mentioned you will GRENADE the D35? <img border="0" title="" alt="[Wink]" src="wink.gif" /> There is a LOT more to that lift than putting big springs on top of the axles <img border="0" title="" alt="[Wink]" src="wink.gif" />
post #6 of 11 Old 05-10-2002, 05:06 PM
HighHooder
listen to Keith, he knows what he's talking about... :flipoff2:
you are now owned by ME!!!
HighHooder is offline
post #7 of 11 Old 05-10-2002, 05:08 PM
Keith Strong
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by HighHooder:
<strong>listen to Keith, he knows what he's talking about... :flipoff2:</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">How is the IFS holding up Tommy???
post #8 of 11 Old 05-10-2002, 08:47 PM
jeep_fun
look at my specs below....good enough? i am gonna put on a 9" from somewhere in the front but i may build it myself. thanx for the info....this probably wont be for a while..350 and components must go in first
yellow '91 YJ
jeep_fun is offline
post #9 of 11 Old 05-11-2002, 10:40 AM Thread Starter
bigjeep39
bigjeep39's Avatar
YOUR JEEEP LOOKS awsome!!, keith i really like how large your jeep looks its bad ***....
So i need a LOT of money, i was planning on doing the d44 in the rear and i got the sye and i will do tranny mods in the future and a d44 upfront in the future, i just like bigjeeps, will the stock 6 handle all i got comin'...
THanks for all the help you guys gave me and again, NICE JEEP!!! (now i know what i have to look forward too)
Shawn
1998 TJ
post #10 of 11 Old 05-15-2002, 03:04 PM
Keith Strong
Thanks, I am not here much, so I missed your compliments.
Plan for a lot of work and a lot of frustration if you want to be big. If you aren't planning on USING it for extreme crawling, dont bother, put it on 35's and drive it around to look cool <img border="0" title="" alt="[Wink]" src="wink.gif" /> My junk is barely streetable anymore, and I have chosen to make it a trailer queen now
post #11 of 11 Old 05-15-2002, 03:13 PM
Keith Strong
A couple more recent ones for you
<img src="http://www.foothill.net/~kdapore/fordyc_05_02/Keith%20mid%20driveline%20hill.JPG" alt="" />
<img src="http://www.pirate4x4.com/forum/attachment.php?s=&postid=552031" alt="" />
A Couple of other RPS guys.
<img src="http://www.pirate4x4.com/forum/attachment.php?s=&postid=552132" alt="" />
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 08:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 07:46 AM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 07:32 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 06:59 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 10:04 AM
