Lift Kits - JeepForum.com
post #1 of 13 Old 12-02-2001, 02:55 PM Thread Starter
AllanAlxndr
Lift Kits
What does everyone think on the SkyJacker 4" lift kit, or the 4" Super lift...
What about some other lifts... I am looking into getting a new one...
Thanks
Allan
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #2 of 13 Old 12-02-2001, 06:10 PM
osburn
osburn's Avatar
I wouldn't touch a Skyjacker lift. Horrible reputation on YJs and CJs alike. The Superlift is better, but still not known for lasting forever. I still don't think any production kit out there comes close to the performance you'll get from the RE 4.5" Extreme Duty. Not to mention the RE lift is the only complete lift out there. Why the other lifts never include a drop pitman arm I still don't understand. Pay more, but pay once.
Matt Osburn
Score 1032
osburn is offline
post #3 of 13 Old 12-02-2001, 08:19 PM
Newfie
Thanks
Allan
I like my Superlift for my 2.5 (w/o a winch - not for long though) as it's pretty flexy and was resonably priced. In your sig it shows you have a Superlift though, are you not happy with it? Matt is right though the RE XD is the way to go if you got the scratch (wish I did, actually, I prolly go SOA before the RE XD, but that's not what you were asking). Have a buddy who's had a SkyJacker for 6 months and he is looking for something else.
No officer, that wasn't an accident. I did that on purpose...
Newfie is offline
post #4 of 13 Old 12-02-2001, 08:25 PM Thread Starter
AllanAlxndr
The superlift that is on there right now, was on the Jeep when i bought it for this guy.
He didn't take alot of time when putting things on it. He didn't even put a kit on, just springs and a t-case drop.
It is a little bounce. Not sure how old it is but the driver spring is all jacked up...
*'90 Wrangler*
*4 Banger*
Member of
post #5 of 13 Old 12-02-2001, 09:37 PM
Newfie
Springs, u-bolts, bumpstops, sway bar links, shocks, a t-case drop (6 spacers and longer allen key bolts = crap) and track bar relocation brackets are pretty much all you get with a Superlift.
Some of this stuff isn't needed, ie. the track bar relocation bracket for the rear (just dump the bar) and the extended sway bar links can be used to make quick disconnects. Match up the bolts for the t-case drop and used grade 8 hex head bolts (you'll be glad you did when you go to take them out for an SYE). The extended bumpstops aren't needed either if you have a 2" body lift and plan to run 33s (based on my experience), so you can run standard u-bolts as you don't need the larger one to fit over one side of the bumpstop.
But, like Matt said earlier, the RE XD is the way to go if you're going for serious performance from an SUA lift.
Newfie is offline
post #6 of 13 Old 12-02-2001, 09:57 PM Thread Starter
AllanAlxndr
Just one more question. Would the rear drive shaft be ok with the 4.5" suspension lift and the 2" body lift...
How hard would it be to take to 2" body lift off and where could i get some stock body mounts to replace the 2" body lift.
*'90 Wrangler*
*4 Banger*
Member of
post #7 of 13 Old 12-03-2001, 08:15 AM
Newfie
Pretty sure you'll have to go with an SYE and CV d-shaft with the RE XD.
Why do you want to get rid of the body lift? Personally, I like a body lift if for no other reasons than it's easier to clean/paint/work on crap underneath without that annoying body tub in the way...
Newfie is offline
post #8 of 13 Old 12-03-2001, 04:13 PM Thread Starter
AllanAlxndr
Not sure how old the body lift is, but one of the bolts is broke off inside the tub and the body sits a little funny on the frame... Any suggestions on how to fix this problem???
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #9 of 13 Old 12-03-2001, 05:01 PM Thread Starter
AllanAlxndr
Also, Can someone help me out with a SYE...
Brand?
Price?
Where to Buy?
ect?
*'90 Wrangler*
*4 Banger*
Member of
post #10 of 13 Old 12-04-2001, 03:21 PM Thread Starter
AllanAlxndr
Or would it be better to just go with the procomp coil conversion for the extra money. It would give a better ride and with the 5" lift on it from the procomp coil conversion i would have more clearance. Does anyone have any other information on this lift...
What would be better to do..
With either one I would have to do a SYE Right. Or would a CV Driveshaft be better for the same price...
*'90 Wrangler*
*4 Banger*
Member of
post #11 of 13 Old 12-04-2001, 06:08 PM
bigjeep39
bigjeep39's Avatar
Yah, rubicon express all the way i have the 4" dont get that the springs are stiff they are made by pro comp..
in a couple of years or so i will get the re 4.5 and i probably wont need it till then re is really nice
1998 TJ
Slow steady project.
bigjeep39 is offline
post #12 of 13 Old 12-05-2001, 04:08 PM Thread Starter
AllanAlxndr
What about an SYE...
Brand?
Price?
Where to Buy?
ect?
A CV Driveshaft...
Brand?
Price?
Where to Buy?
ect?
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #13 of 13 Old 12-05-2001, 05:19 PM
4-low
if you hop, skip, and jump over to the jeeps unlimitied site, and check out <search for group buys> some guys trying to get a group buy discount on SYE kits for np231, so,, get in on that, it's an advance adapter kit, and something like 300 bucks.....
4-low is offline
Question about lift kits and spacer kits. EvanQuinn TJ Wrangler Technical Forum 4 01-11-2009 05:21 PM
lift kits jeepwrnglr92 YJ Wrangler Technical Forum 6 07-17-2007 10:35 AM
Lift Kits D0ntTr3ad0nM3 YJ Wrangler Technical Forum 23 03-26-2007 11:52 AM
will my body lift affect future lift kits??? SouthernMoose TJ Wrangler Technical Forum 6 10-22-2006 08:34 PM
BDS lift kits? stillspiraling TJ Wrangler Technical Forum 3 10-30-2001 12:07 PM
