Lift kits - JeepForum.com
post #1 of 25 Old 10-20-2012, 06:18 PM Thread Starter
MathewWalsh
Lift kits
I want to lift my jeep 2-4 inches. Would I have to adjust any of my gauges or would the difference not be large enough to bother? And what kits would you recommend? Both body and suspension. Thanks for the help, you guys always throw me something useful
MathewWalsh is offline
post #2 of 25 Old 10-20-2012, 06:41 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
What size tire do you want to run and what do you plan on doing with your jeep? That's a basis for the answer you shall get.
None of your gauges will change just by lifting it. Tire size will change your speedometer though.
Michaelgoesrawr is offline
post #3 of 25 Old 10-20-2012, 06:57 PM Thread Starter
MathewWalsh
Not too sure, I was thinking 33s or a little bigger
post #4 of 25 Old 10-20-2012, 07:01 PM
imstillatwork
bigger than 33 and I would suggest really, really thinking about what you wan tot do. over 33" and you need quite a lift, SYE, and need to seriously consider axle strength.
imstillatwork is offline
post #5 of 25 Old 10-20-2012, 07:05 PM
ashland82391
The 3.5" fabtech is cheap with great performance. Will look good with 33's or 35's.
ashland82391 is offline
post #6 of 25 Old 10-20-2012, 07:20 PM
NHfireLJ
NHfireLJ's Avatar
What he said.... Speedo is an easy fix with a new speedo gear after you select your set up...
A 1" BL (body lift) is the usual recommendation (no taller, increased stresses on mounts and looks funny)
Along with a quality 2" spring lift (OME , RE) NOT ROUGH COUNTRY, will get you 33" tires.
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #7 of 25 Old 10-20-2012, 07:21 PM
Michaelgoesrawr
Personally, I wouldn't go more than 33's with your Jeep. Your engine doesn't have the power to push bigger tires with your gearing so 33's will be fairly dog-ish. And as imstillatwork said, to run 35's you will need to start looking at rear axle strength.
You also need to keep in mind that they higher you go, the more work you need to do. General rule of thumb is that anything over 2.5" of suspension lift and should get an sye and new drive shaft(about $600 on it's own). So at this point you need to look at home much you want to spend to get it where you want to be and you always get what you pay for in terms of suspension parts, so try to stay away from rough country.
I would go with an OME, BDS, or RE 2-2.5" suspension lift and a 1" body lift at the most. You can forgo the body lift in favor of TJ flares or flat fenders if you would like.
EDIT: ^^He beat me to it and I agree with what he says.
post #8 of 25 Old 10-20-2012, 09:13 PM Thread Starter
MathewWalsh
So what if I did 31 inch tires, and a two inch suspension lift? Would that be alright, not any work after that?
post #9 of 25 Old 10-20-2012, 09:18 PM
Michaelgoesrawr
I think that would be spot on. I think BDS has a 2" lift.
post #10 of 25 Old 10-20-2012, 10:07 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
2" BDS springs
5/8" Besrk or vacj5 shackles
1" daystar body lift
Tj flares in rear
http://www.jeepforum.com/forum/f12/h...enders-1087408
^^ front fenders
No bumpstops
No trackbar
Swaybar disconnects
It'll be the best flexing system and best daily driver you'll ever have. You'll thank yourself in the end.
Luck Favours The Prepared
Anticanman is offline
post #11 of 25 Old 10-20-2012, 10:25 PM
sdotcarter
put this in its own end all sticky plz.
2" BDS springs
Tj flares in rear
^^ front fenders
No bumpstops
No trackbar
Swaybar disconnects
sdotcarter is offline
post #12 of 25 Old 10-21-2012, 09:11 AM
RockWoRM
RockWoRM's Avatar
to add...
If your'e not wanting invest some extra coin, then yes, that would work. Above and beyond that, and you'll loose too much power d-line work will be needed, as has been pointed out already.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #13 of 25 Old 10-21-2012, 06:37 PM
Mameluke
2" BDS springs
Tj flares in rear
^^ front fenders
No bumpstops
No trackbar
Swaybar disconnects
this is what i wish i had done. i got carried away and did a 3.5" BDS, with shackles, and a 2" BL (on 33s). it's a little higher than i wanted, and i'm considering just taking the body lift completely out.
Mameluke is offline
post #14 of 25 Old 10-21-2012, 07:01 PM Thread Starter
MathewWalsh
2" BDS springs
Tj flares in rear
^^ front fenders
No bumpstops
No trackbar
Swaybar disconnects
So I'll still be able to use this as my daily driver after these suspension mods? How much would this run me? I'd look it all up on my own but I've been busy and only on mobile lately
post #15 of 25 Old 10-21-2012, 07:12 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You'll be fine with it as your daily driver. Mine is a little taller and its still my daily driver.
