lift kit questions (small as possible) - JeepForum.com
post #1 of 24 Old 04-25-2013, 10:56 PM Thread Starter
Brian96
What lift kit will I need to be able to fit some 37x13.50 pitbull rockers without rubbing? I'll have fullwidth d60 front and 14 bolt ff rear with 3 inch fender flares front and back from poison spyder. Keep it as low as possible for stability on the trail and reliability.
Brian96 is offline
post #2 of 24 Old 04-25-2013, 11:05 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You'll be better off with a coil suspension because fine tuning the girth of the axles mentioned will be extremely difficult. The lowest I think you can go is stock springs SOA.
Luck Favours The Prepared
Anticanman is offline
post #3 of 24 Old 04-25-2013, 11:08 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Skip a kit like you skipped other things. Don't be a dork.
Joe Dillard is offline
post #4 of 24 Old 04-25-2013, 11:21 PM
zte87
GIVE IT THE ONION
zte87's Avatar
I am no where wide as you but I am running sua 4 inches of lift with my 37-12.50 pbr's
zte87 is offline
post #5 of 24 Old 04-27-2013, 11:15 AM Thread Starter
Brian96
I waw thinking about that, how hard is it to switch from leaf to coilover?
Brian96 is offline
post #6 of 24 Old 04-27-2013, 11:15 AM Thread Starter
Brian96
What do you mean? Im not skipping out on much
Brian96 is offline
post #7 of 24 Old 04-27-2013, 04:00 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It is quite labor intensive.
post #8 of 24 Old 04-27-2013, 04:52 PM
Ripper3494
From the looks of it your not ready. Like Anticanman said. It's very labor intensive. And if you want coilovers to perform to their potential you'll need to brush up on your trigonometry.
Sent from AutoGuide.com App
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #9 of 24 Old 04-27-2013, 10:14 PM
JohnnyZJ
Cut fenders a 4" spring under should do it. Those axles should net you a few inches of lift too
07' JKUR rollin on 35s
JohnnyZJ is offline
post #10 of 24 Old 04-27-2013, 10:17 PM
zte87
GIVE IT THE ONION
zte87's Avatar
If you went sua with those axle you will acutely loose lift!
zte87 is offline
post #11 of 24 Old 04-27-2013, 10:29 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If you went sua with those axle you will acutely lose lift!
Exactly.
post #12 of 24 Old 04-27-2013, 11:32 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
I'm confused.
I guess that, after reading the parts listed in his post, and then what he's asking, I just assumed he was trolling. And then, I remembered that buying stuff doesn't make you an expert.
But then I thought, "How the hell do you get invested to that point and then try and figure out your lift/set up?" and then I remembered not everything on the interwebs is true.
I think Joe said it best - Don't be a dork.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luuca is offline
post #13 of 24 Old 04-28-2013, 10:33 PM Thread Starter
Brian96
I'm confused.
Im not trolling im just asking which lift kit and size would be best to fit a 37 inch pbr with some 3 inch fender flares. Haha a little misunderstood... and I think I'll stick with leaf springs looking at the pricing for coilover kits. Im thinking like a 2.5 inch lift? Or would I want to do a 3 or 4 inch lift?
Brian96 is offline
post #14 of 24 Old 04-28-2013, 11:31 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Here's my setup with 4 inches of lift, now keep in mind mine a sua with 30/8.8 combo (I know the Dana 30 and 37s is a no no but I am only running a 2.5 and have chromo shafts up front) I am sure I could run smaller lift if I where to properly bump stop it!
image-2170026384.jpg   image-243452784.jpg   image-3016900251.jpg   image-3859632704.jpg
zte87 is offline
post #15 of 24 Old 04-29-2013, 11:17 AM Thread Starter
Brian96
Thats a sweet jeep! What beadlocks do you have on there? It looks really good. That's pretty much exactly what I'm looking at doing. How stable is it on the trail??
Brian96 is offline
