Lift kit help - JeepForum.com
post #1 of 9 Old 02-24-2013, 05:08 PM Thread Starter
Ryfree94
Lift kit help
Ok so I currently own a 93 YJ. And when I got it a 3in body lift was installed on it. And it rides really rough. So I want to buy a suspension lift for it. And my question is, What lift will fit my tires? cause ive seen that a 3-4in lift will fit 33's. But currently I have 35's on my BODY lift. So im not sure what to look for when I buy a lift kit. Cause I love my hight now and I would hate to go higher.
Ryfree94 is offline
post #2 of 9 Old 02-24-2013, 05:56 PM
YJwrangler1990
Just get a new stock suspension. The new height isn't going to make it ride any smoother. If you want smoother buy the expensive old man emu suspensions or something expensive cause my new RC suspension lift it still rough
YJwrangler1990 is offline
post #3 of 9 Old 02-24-2013, 06:03 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Get rid of the body lift.
Luck Favours The Prepared
Anticanman is offline
post #4 of 9 Old 02-24-2013, 06:05 PM
Mark05059
if you never have experienced OME suspension then how can you compare them. I hope you enjoy changing your RC springs once every couple years when your 4 inch springs sag to about an inch lift.
To the OP: OME is very good. You will Need to upgrade the shocks when you put them on. The 3" bodylift should be removed and a 1" daystar put in its place. What ever you do dont buy Rough Country springs... well rough country anything for that matter.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 9 Old 02-24-2013, 08:30 PM
YJwrangler1990
Because I used to have ome suspension... You have an RC lift or something?
post #6 of 9 Old 02-24-2013, 08:44 PM
jeepngolf
to the OP: there must be more to the story for you to fit 35's with only a 3 inch body lift. I would bet that there are lift shackles involved also. The lift shackles should also go away if you find you have them. I agree with the other poster about getting rid of the 3" body lift and install a 1" body lift in its place. You should spend some time researching the various lift manufacturers and tie that in with a budget. If it were my money I would buy the best possible lift I could afford. Rubicon Express is what I have and it has not let me down. I have heard great things about BDS and Old Man Emu. Remember also that getting a 4 inch lift will most likely involve the need for a slip yoke eliminator kit and a new rear driveshaft.
jeepngolf is offline
post #7 of 9 Old 02-25-2013, 12:33 PM
Siva283
Also OME and BDS(I have BDS) is not much more that Rough Country but it will ride nice and not sag where Rough Country is called that for a reason. Even on a smooth asphalt road itll feel like you are off road.
Ask me how I know...
Siva283 is offline
post #8 of 9 Old 02-25-2013, 03:03 PM Thread Starter
Ryfree94
You know im starting to think that i have a lift other than the body lift as well. but again i dont know anything about lift kits. but i think your right. I need to start researching around.
Ryfree94 is offline
post #9 of 9 Old 02-25-2013, 04:06 PM
jimbob78cj
Google is your friend. Look at lots of pictures. You'll get an idea of what stock looks like and how yours differs. Keep in mind that tire "fitment" can mean different things to different people depending on how you plan to use your Jeep. Mostly on-road driving with a little light trail ridding won't need nearly the amount of flex (i.e. wheelwell space) as a dedicated rock crawler.
-jim
'78,'79,'82 CJ5 with many extra parts
'93 YJ pretty much stock
"Stupid Should Hurt" - Bumper sticker seen on Jeep
jimbob78cj is offline
